Salve volevo chiedere delle delucidazioni in base all'alimentazione che si può dare ad arduino. Oltre alla batteria da 9 volt base in che altro modo si può alimentare e quali sono i limiti minimi e limiti massimi da non superare? Per progetti stand alone come faccio a calcolare l'alimentazione ideale che necessita il circuito?
questo lo potresti trovare scrivendo su Google: "Arduino Uno/Mega Datasheet" comunque trovi tutto qui >>
fonzy9114:
Quale modello di Arduino hai?
Ciao Uwe
Arduino uno.
http://arduino.cc/en/Main/ArduinoBoardUno:
PowerThe Arduino Uno can be powered via the USB connection or with an external power supply. The power source is selected automatically.
External (non-USB) power can come either from an AC-to-DC adapter (wall-wart) or battery. The adapter can be connected by plugging a 2.1mm center-positive plug into the board's power jack. Leads from a battery can be inserted in the Gnd and Vin pin headers of the POWER connector.
The board can operate on an external supply of 6 to 20 volts. If supplied with less than 7V, however, the 5V pin may supply less than five volts and the board may be unstable. If using more than 12V, the voltage regulator may overheat and damage the board. The recommended range is 7 to 12 volts.
The power pins are as follows:
- VIN. The input voltage to the Arduino board when it's using an external power source (as opposed to 5 volts from the USB connection or other regulated power source). You can supply voltage through this pin, or, if supplying voltage via the power jack, access it through this pin.
- 5V.This pin outputs a regulated 5V from the regulator on the board. The board can be supplied with power either from the DC power jack (7 - 12V), the USB connector (5V), or the VIN pin of the board (7-12V). Supplying voltage via the 5V or 3.3V pins bypasses the regulator, and can damage your board. We don't advise it.
- 3V3. A 3.3 volt supply generated by the on-board regulator. Maximum current draw is 50 mA.
- GND. Ground pins.
- IOREF. This pin on the Arduino board provides the voltage reference with which the microcontroller operates. A properly configured shield can read the IOREF pin voltage and select the appropriate power source or enable voltage translators on the outputs for working with the 5V or 3.3V.
Ciao Uwe
E per progetti stand alone come faccio a calcolare l'alimentazione ideale che necessita il circuito?
fonzy9114:
Prendendo un bel libro d'elettronica e STUDIANDO ! ]![]()
Ma che domanda è ???
Cosa vuol dire "... l'alimentazione ideale che necessita il circuito" ??? ![]()
Che valori vuoi esattamente sapere e che ...
... non puoi ricavare da solo leggendo/studiando il datasheet (da pagina 303 in poi) ???
Guglielmo
Con alimentazione ideale intendevo che tipo di batterie usare e quante e inoltre come calcolare il consumo totale di un circuito che costruisco. Sicuramente un libro sarebbe l'ideale ma scrivo qui anche per imparare facendo domande agli altri e sicuramente non per aver "la pappa pronta", sbaglio o è questo l'utilizzo di un forum di questo tipo?
fonzy9114:
SBAGLIATO, le due cose dovrebbero andare di pari passo perché le domande possono certamente servire a chiarire dei concetti poco chiari, ma i concetti ... vanno studiati sui libri !
Mi sembra che ... dici di non volerla, ma in verità stai chiedendo esattamente la "la pappa pronta" ... visto che calcolare "più o meno" gli assorbimenti di uno standalone ... è questione di studiare bene un datasheet (... e ti ho anche indicato esattamente dove guardare) e applicare bene la legge di Ohm ![]()
Guglielmo
Inoltre ... mi sembra che stai anche contravvenendo al regolamento facendo crossposting, dato che ...
... le stesse richieste le stai facendo QUI dove ti stanno già dando il supporto necessario.
Quindi ... questo thread verrà chiuso al prossimo passaggio di un moderatore. ![]()
Mio errore, stesso argomento, ma utenti diversi !!!
Guglielmo
Se noti gli utenti sono differenti e le richieste anche. Inutile continuare, buon proseguimento.
fonzy9114:
Allora chiedo scusa, mio errore, ... l'argomento era praticamente identico ...
... e comunque allora puoi trovare le risposte che cerchi di la ![]()
Guglielmo
