All A Ports Reading Weird
Was following a Paul McWhorter video and was hookin up a thing to read out the analog and does a thing when it gets to 1000 or higher.
I was turning a potentiometer and nothing changed execept sometimes jumping to 700ish, 1023 for one line every once in a while. Started trouble shooting, plugged the A0 I was reading from to ground and was still 14. Tried at A1 and got 15, A2 was 16, etc.
Any clue what's up? <3
Hi, welcome to this forum.
There are breadboards with bad contacts and broken jumper wires. This seems to happen more often lately.
Do you have a multimeter ? Can you check if a wire is good ? If you do not use a breadboard but directly put it in the Arduino board, then A0 to GND should give a value of 0 and A0 to 5V should give 1023.
The impedance of the inputs is extremely high. When a input is not connected it might go up and down with a nearby voltage.
and ckeck your potentiometer using the voltmeter, too.
We need to see good images of the wiring :wink: .
Hi, @clausisgreat
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
We need info such as;
What model Arduino.
A circuit diagram.
A picture of your project so we can see you component layout.
Post a link to the YouTube (I assume) video.
Thanks.. Tom... :grinning: :+1: :coffee: :australia:
This sounds like you are printing the pin number, not reading the input! Please post YOUR code, and we will be happy to help.
