All bits on CD4021BE are high
Hello,
I am trying to daisy chain multiple CD4021BE IC's to have more inputs. The first one works fine, but the 2nd one gives me a byte of all 1's when I press a button. Not all inputs are connected, but the ones that aren't connected I tried connecting with ground, to no avail.
I wired them like the ShiftIn tutorial suggests:
The code:
//  Name    : shiftIn Example 2.1                               //
//  Author  : Carlyn Maw                                        //
//  Date    : 25 Jan, 2007                                      //
//  Version : 1.0                                               //
//  Notes   : Code for using a CD4021B Shift Register       //
//define where your pins are
int latchPin = 8;
int dataPin = 9;
int clockPin = 7;
//Define variables to hold the data
//for each shift register.
//starting with non-zero numbers can help
//troubleshoot
byte switchVar1 = 72;  //01001000
byte switchVar2 = 159; //10011111
  //start serial
  //define pin modes
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, INPUT);
  //Pulse the latch pin:
  //set it to 1 to collect parallel data
  digitalWrite(latchPin,1);
  //set it to 1 to collect parallel data, wait
  delayMicroseconds(20);
  //set it to 0 to transmit data serially
  digitalWrite(latchPin,0);
  //while the shift register is in serial mode
  //collect each shift register into a byte
  //the register attached to the chip comes in first
  switchVar1 = shiftIn(dataPin, clockPin);
  switchVar2 = shiftIn(dataPin, clockPin);
  //Print out the results.
  //leading 0's at the top of the byte
  //(7, 6, 5, etc) will be dropped before
  //the first pin that has a high input
  //reading
  Serial.println(switchVar1, BIN);
  Serial.println(switchVar2, BIN);
//white space
Serial.println("-------------------");
//delay so all these print satements can keep up.
//------------------------------------------------end main loop
////// ----------------------------------------shiftIn function
///// just needs the location of the data pin and the clock pin
///// it returns a byte with each bit in the byte corresponding
///// to a pin on the shift register. leftBit 7 = Pin 7 / Bit 0= Pin 0
byte shiftIn(int myDataPin, int myClockPin) {
  int i;
  int temp = 0;
  int pinState;
  byte myDataIn = 0;
  pinMode(myClockPin, OUTPUT);
  pinMode(myDataPin, INPUT);
//we will be holding the clock pin high 8 times (0,..,7) at the
//end of each time through the for loop
//at the begining of each loop when we set the clock low, it will
//be doing the necessary low to high drop to cause the shift
//register's DataPin to change state based on the value
//of the next bit in its serial information flow.
//The register transmits the information about the pins from pin 7 to pin 0
//so that is why our function counts down
  for (i=7; i>=0; i--)
    digitalWrite(myClockPin, 0);
    delayMicroseconds(2);
    temp = digitalRead(myDataPin);
    if (temp) {
      pinState = 1;
      //set the bit to 0 no matter what
      myDataIn = myDataIn | (1 << i);
    else {
      //turn it off -- only necessary for debuging
     //print statement since myDataIn starts as 0
      pinState = 0;
    //Debuging print statements
    //Serial.print(pinState);
    //Serial.print("     ");
    //Serial.println (dataIn, BIN);
    digitalWrite(myClockPin, 1);
  //debuging print statements whitespace
  //Serial.println();
  //Serial.println(myDataIn, BIN);
  return myDataIn;
Any idea what could be going wrong here?
Kind regards,
topiek
No bypass caps.
Does your breadboard have gaps in the red and blue bus lines?
Paul__B:
No, I connected those across both breadboards.
PaulRB:
No bypass caps.
I'll have a look into those!
PaulRB:
No bypass caps.
This fixed it!
topiek:
This fixed it!
Excellent. Thanks for reporting the solution back to the forum. +1 karma
