SUCCESSFUL ARDUINO “COMPILES”: I received a Uno WiFi Rev2 and my first successful sketch (to compile and run) was Jon_LSM6DS3_Arduino_Simple from www.woolseyworkshop.com, on 10/08/2020. I added the (Jon)_so that I can recall where it came from. The “successful” sketches directory now contains 30 basic sketches which are from the Arduino site and several web sites.
PROCESSING WITH FIRMATA: About 11/13/2020 I started to study Firmata sketches and attempted to compile the Arduino examples. My project is a Control/Monitoring program for a solar tracker system and it seems that using the Firmata protocol would be good. I have read some articles which discuss using Firmata and/or Processing with Firmata. I started working my way through the majority of “example Firmata” sketches but all produced error messages.
At that time, my Arduino IDE was Arduino 1.8.13 Nightly. My first attempted compile returned a message to edit the boards.h file to add my board. I found a boards.h header (2009-2016 Jeff Hoefs. Last updated April 10th, 2016) that contained information about the Uno WiFi Rev 2 and I replaced the original file which seemed to stop that error.
MY LAST ATTEMPT: After the failed attempts with the “example” Firmata sketches I made a last attempt with the sketch FirmataExpress which was last updated May 10, 2020 by Alan Yorinks. The errors are all similar and list problems with either the .h or .cpp of FirmataMarshaller. I have not altered the code on any of the examples or the FirmataExpress sketch which is discussed below.
ERRORS FROM LAST ATTEMPT WITH FirmataExpress which was last updated May 10, 2020: A few errors (which are typical) are included below.
TYPICAL ERRORS -------------------------------------------------------------------------------------
C:\Users\keith\Documents\Arduino\libraries\FirmataExpress\FirmataMarshaller.cpp:27:0:C:\Users\keith\Documents\Arduino\libraries\FirmataExpress\FirmataMarshaller.h:47:16: error: 'Stream' has not been declared void begin(Stream &s);
^~~~~~C:\Users\keith\Documents\Arduino\libraries\FirmataExpress\FirmataMarshaller.h:78:5: error: 'Stream' does not name a type; did you mean 'fread'? Stream * FirmataStream;
^~~~~~ freadC:\Users\keith\Documents\Arduino\libraries\FirmataExpress\FirmataMarshaller.cpp: In member function 'void firmata::FirmataMarshaller::reportAnalog(uint8_t, bool) const':C:\Users\keith\Documents\Arduino\libraries\FirmataExpress\FirmataMarshaller.cpp:55:9: error: 'Stream' was not declared in this scope if ( (Stream *)NULL == FirmataStream ) { return; }
^~~~~~C:\Users\keith\Documents\Arduino\libraries\FirmataExpress\FirmataMarshaller.cpp:55:9: note: suggested alternative:In file included from C:\Users\keith\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.6\cores\arduino/api/deprecated/Stream.h:23:0, from C:\Users\keith\Documents\Arduino\libraries\FirmataExpress\FirmataMarshaller.h:34, from C:\Users\keith\Documents\Arduino\libraries\FirmataExpress\FirmataMarshaller.cpp:27:c:\users\keith\appdata\local\arduino15\packages\arduino\hardware\megaavr\1.8.6\cores\arduino\api\stream.h:50:7: note: 'arduino::Stream' class Stream : public Print
^~~~~~C:\Users\keith\Documents\Arduino\libraries\FirmataExpress\FirmataMarshaller.cpp:55:17: error: expected primary-expression before ')' token if ( (Stream *)NULL == FirmataStream ) { return; } ^In file included from c:\users\keith\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5\avr\include\avr\pgmspace.h:89:0, from
The errors pointed to a problem within my Arduino settings and I uninstalled, deleted all the files that I could locate and reinstalled Arduino: 1.8.14 Hourly - (Windows 10), which is now installed. After the reinstall I still got the same errors.
Thank you for any attention KK.
posted on -- Interfacing w/ Software on the Computer
Firmata, Processing, Max/MSP, PureData, VVVV, etc.
