ALL Green But No Go
UKHeliBOB solved my error code, and im not sure how but its gone, But now I have code that loaded
up all green and no errors but no joy, and nothing will print out on the serial monitor either.
here is the code that loads up all green--if anyone sees whats wrong please tell me.
Thank you
int redPin=9;
int numblinks=10;
int redOnTime=500;
int redOffTime=250;
String redMessage="The red led is blinking";
pinMode(redPin , OUTPUT);
Serial.println(redMessage);
Serial.print("you are on blink #: ");
digitalWrite(redPin, HIGH);
delay(redOnTime);
digitalWrite(redPin, LOW);
delay(redOffTime);
Show us a good schematic & image of your circuit.
Posting images:
Is your serial monitor set to 9600?
ALL Green But No Go
What the Hell does that mean?
Please remember to use code tags when posting code
Yes--serial monitor is matched to serial port at 9600 baud
Posting images:
All your code does is the following:
  • Display "The red led is blinking", then go to the next line.
  • After that, it loops the following :
  • Display "you are on blink #: The red led is blinking" and blink the led, skip line
That's all : no green whatsoever (I like that word :slight_smile: )
yes I know, but thats my point, nothing is printing to the serial monitor at all
Let’s have another go…
int redPin=9;
 int numblinks=10;
 int redOnTime=500;
 int redOffTime=250;
 delay(redOnTime);
 delay(redOffTime);
Is serial monitor configured at 9600 bps ?
You never use numb links or increment it…
– doesn’t actualy tell you anything about numb links.
And while we’re there - a good time to stop using String.
zerotact:
But what the Hell has that got to do with "green"?
zerotact:
Works OK fro me
Sample output
It is nonsense but it does print
How about trying this :
int redPin=9;
 int numblinks=1;
 int redOnTime=500;
 int redOffTime=250;
  Serial.println(numblinks);
 delay(redOnTime);
 delay(redOffTime);
 numblinks++;
When you upload the sketch does the IDE say "Done uploading" in the green bar below your sketch? Trying to determine if you are hitting verify instead of upload.
The 9600 baud value has to appear in two places, one in your sketch which we can see and another at the bottom of the serial monitor.
Great, UKHeliBOB--you have it working and it still does not work on my pc, maybe there is
something wrong other than the code. yah, I thought the code would just put in the numbers--
1-2-3-etc, I guess not--no wonder it makes no sense.
Try this
	Serial.println("Hello World");
Make sure that the baud rate in the Serial monitor is set to 9600
What do you see printed in the Serial monitor ?
No that does not print either--Damn--whats going on
Time for silly questions
Are you sure that you are uploading the code ? How do you know ?
Are you actually opening the Serial monitor ?
What baud rate is the program set to ? What baud rate is the Serial monitor set to ?
This sketch will only work if your PC has an external green colour.
A can of green spray paint might be the answer.
The RED pc board does not do Green.
The code does print....Confirmed.
How
do
copy
the
monitor
display
here???
Click in the display
Ctrl and A on the keyboard to select all of the output
or left click and select part of it using the mouse
Ctrl and C to copy the selected text to the clipboard
