Allocating memory for ADC samples
Hi, I am currently designing a project where I need to take a sample from one of the ADC's on my arduino board every 3 seconds. I need to save 200 samples (i.e. 10 minutes worth) which are sent back to a PC once they are requested.
the problem I have is that the ADC resolution is 10-bit. I initially thought it was 8-bit so I defined an array of type byte with 200 locations. My questions is, is there anyway to define memory in 10-bit words or must I use type int? (Which I presume allocates way more bits than actually required?) I am worried that I may not have enough memory for other parts of the program.
Alternatively, if I cannot allocate the memory more economically, is there a way to ignore the 2 lsb's of the 10-bit sample and still use a byte of memory for each sample at reduced resolution.
Thanks for any ideas
200 "int" samples (16 bits), so 400 bytes. It ain't gonna break the bank (unless you've got a huge program with lots of other variables.
You can ignore the 2 LSB's by shifting the read value right by 2 bits:
(unsigned char) (analogRead(pin) >> 2)
Thanks for the replies. I didn't realise an int was only 16 bits, well in that case I'll use ints. I always thought an int was 32 bits but that must be a float.
Anyway I think I should be ok using ints and if not I can use the method described in the second post to shift to the right.
Thanks again for the advice.
The size of an int is implementation dependant, so it can be 32 bits, but on the AVR, it's 16.
