Allow a numberrange in URL without "uriRegex.h"
Hello again!
I'm looking for some advice for my Webserver.
from my application i get a POST request with an empty body. So that means i get a POST request and all the info I need I get from the URL which my application is sending to.
All reachable URL's should cover those cases, but without initialising each and everyone, one by one:
IP/command/on or off/number between 1-n
So for Example if i want to turn off my led on pinnumber 20 i send my POST request on the following URL:
IP/command/off/20.
At first I fixed this problem by the following line of Code:
server.on(UriRegex("^\\/command\\/([on,off]+)\\/([0-9]+)$"),handlePostRequest );
But now i can't use the WebServer.h library anymore and to be honest, this wasnt really a good solution, since the only thing that happened is, that i allow number in the URL between 1 and 9.
Now i want to ask if someone knows a more "elegant" way to work around that problem.
Thanks in advance!
So why exactly do you use a POST request instead of a simple GET request?
Tokenize at the '/' character and parse each token separately.
why? Did your instructor forbit it?
I had to switch over to https. And I’m using a 3rd party library, since I didn’t found a arduino Library. This library provides a wrapper, so I can use it with the WebServer.h API so I don’t have to rewrite my code
Because my instructor told me to. Sadly I’m new at the company and I don’t want to start a discussion.
What do you mean by tokenize ?
Hello,
I don't understand what is your problem, explain better
And, your regex looks wrong, this part ([on,off]+) should be (on|off) (and also you could replace [0-9] by \d)
Hello @guix ,
yeah sure.
So basically i got an application. and i want the application to communicate with my webserver. To communicate with my webserver i use a 3rd-person library to implement HTTPS.
The communication im talking about should be done by a bodyless HTTPS POST request. All my Information I should receive by getting all the Data in my URL.
Basically i want to give the application 2 parameters to choose of. 1.= On or Off and 2. = number between 1 and x(lets say 32).
So for example the URL look like this: https://myipadress/command/on/5
that means i send a on signal for the number 5(could be a LED or anything else).
But before I'm able to reach my webserver with this URL I have to initialize this exact URL with the server.on() function.
and there's my problem. I dont want to initialize every URL one by one. Is there a possibillity without using UriRegex where i can say = just accept requests by the number between 1 and 32.
I don't know much about this, but normally parameters are done like this:
https://myipadress/?command=on&value=5
See this example
Yeah i would also do the same. But since i didn't make the app, i cant really change the way it is. So I'm getting a path and not really a value. I think this makes it more clear.
Maybe with server.onNotFound then in its handler function you parse server.uri() to get the parameters? Just an idea, I really don't know if that will work
well,
I'm not sure. But i think this is not the way to go. I solved it now, by initializing every single one with a for-loop now.
But thanks for your advice anyways!
strtok
