Although I have previously gotten a similiar idea to work with a servo and millis the timing all worked out because the servo didn't have to spin unless it got a specific signal from an RC reciever. Now that I just want the servo to be constantly rotating back and forth I am having trouble getting it to move smoothly and not jitter. I'm pretty sure it's because the time is constantly telling the servo to move in both directions but I'm not sure what the best way to fix this problem would be. Any insight would be great.
#include <Servo.h>
#include <NewPing.h>
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_MS_PWMServoDriver.h"
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_DCMotor *drive = AFMS.getMotor(1);
Adafruit_DCMotor *steer = AFMS.getMotor(2);
#define TRIGGER_PIN A1
#define ECHO_PIN A0
#define MAX_DISTANCE 75
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
Servo ultraSonic;
int servoPin = A2;
int pos = 0;
unsigned long previousMillis = 0;
unsigned long previousMillis2 = 0;
unsigned long previousMillis3 = 0;
long onTime = 1;
long onTime2 = 40;
long onTime3 = 40;
AFMS.begin();
drive->setSpeed(255);
steer->setSpeed(255);
ultraSonic.attach(servoPin);
int distance = sonar.ping_in();
Serial.print("Ping: ");
Serial.print(distance);
Serial.println("in");
if(currentMillis - previousMillis2 > onTime2)
for(pos = 20; pos < 110; pos++)
ultraSonic.write(pos);
previousMillis2 = currentMillis;
if(currentMillis - previousMillis3 < onTime3)
for(pos = 110; pos > 20; pos--)
previousMillis3 = currentMillis;
if(distance >= 10)
drive->run(FORWARD);
steer->run(FORWARD);
if((distance < 10) && (distance > 0))
if(currentMillis - previousMillis >= onTime)
drive->run(BACKWARD);
steer->run(BACKWARD);
if(distance == 0)
