Almost there. Wrong Output
// SWIM TIMES
  Serial.println("Enter Swim Hours");
  int totalSwimHours;
 while (!Serial.available()) {
 //wait for a the user to enter a value
 totalSwimHours = Serial.parseInt();
  Serial.println("Enter Swim Minutes");
 int totalSwimMinutes;
 totalSwimMinutes = Serial.parseInt();
  Serial.println("Enter Swim Seconds");
 int totalSwimSeconds;
 totalSwimSeconds = Serial.parseInt();
int hourSwimResult;
hourSwimResult = totalSwimSeconds + totalSwimMinutes * 60 + totalSwimHours * 3600;
int minuteSwimResult;
minuteSwimResult = totalSwimSeconds + totalSwimMinutes * 60 + totalSwimHours * 3600;
int secondSwimResult;
secondSwimResult = totalSwimSeconds + totalSwimMinutes * 60 + totalSwimHours * 3600;
 Serial.println("-----------------");
// BIKE TIMES
  Serial.println("Enter Bike Hours");
 int totalBikeHours;
 totalBikeHours = Serial.parseInt();
  Serial.println("Enter Bike Minutes");
 int totalBikeMinutes;
 totalBikeMinutes = Serial.parseInt();
  Serial.println("Enter Bike Seconds");
 int totalBikeSeconds;
 totalBikeSeconds = Serial.parseInt();
 int hourBikeResult;
hourBikeResult = totalBikeSeconds + totalBikeMinutes * 60 + totalBikeHours * 3600;
int minuteBikeResult;
minuteBikeResult = totalBikeSeconds + totalBikeMinutes * 60 + totalBikeHours * 3600;
int secondBikeResult;
secondBikeResult = totalBikeSeconds + totalBikeMinutes * 60 + totalBikeHours * 3600;
// RUN TIMES
  Serial.println("Enter Run Hours");
 int totalRunHours;
 totalRunHours = Serial.parseInt();
  Serial.println("Enter Run Minutes");
 int totalRunMinutes;
 totalRunMinutes = Serial.parseInt();
   Serial.println("Enter Run Seconds");
 int totalRunSeconds;
 totalRunSeconds = Serial.parseInt();
int hourRunResult;
hourRunResult = totalRunSeconds + totalRunMinutes * 60 + totalRunHours * 3600;
int minuteRunResult;
minuteRunResult = totalRunSeconds + totalRunMinutes * 60 + totalRunHours * 3600;
int secondRunResult;
secondRunResult = totalRunSeconds + totalRunMinutes * 60 + totalRunHours * 3600;
// Total of everything
Serial.println ("Total Time:");
 int totalHours;
totalHours = (hourRunResult = totalRunSeconds + totalRunMinutes * 60 + totalRunHours * 3600) +
(hourBikeResult = totalBikeSeconds + totalBikeMinutes * 60 + totalBikeHours * 3600) +
(hourSwimResult = totalSwimSeconds + totalSwimMinutes * 60 + totalSwimHours * 3600);
Serial.print  (totalHours / 3600);
Serial.print  ("hr");
Serial.print  (" ");
 int totalMinutes;
totalMinutes = (minuteRunResult = totalRunSeconds + totalRunMinutes * 60 + totalRunHours * 3600) +
(minuteBikeResult = totalBikeSeconds + totalBikeMinutes * 60 + totalBikeHours * 3600) +
(minuteSwimResult = totalSwimSeconds + totalSwimMinutes * 60 + totalSwimHours * 3600);
Serial.print  (totalHours % 3600 / 60);
Serial.print  ("min");
Serial.print  (" ");
 int totalSeconds;
totalSeconds = (secondRunResult = totalRunSeconds + totalRunMinutes * 60 + totalRunHours * 3600) +
(secondBikeResult = totalBikeSeconds + totalBikeMinutes * 60 + totalBikeHours * 3600) +
(secondSwimResult = totalSwimSeconds + totalSwimMinutes * 60 + totalSwimHours * 3600);
Serial.print  (totalSeconds % 60);
Serial.print  ("sec");
// Times to input Hr/Min/Sec :
// Test 1 : 0 50 59
//          2 50 59
//          1 50 59  =  5hr 32min 57sec
// Test 2 : 0 50 59
//          0 170 59
//          0 110 59 =  5hr 32min 57sec
// Test 3 : 2 50 02
//          9 20 53
//          6 42 59  =  18hr 53min 54sec
// But it's outputting = 0hr 41min 38sec
Firstly,
I’d like to thank anyone who offered suggestions the other day to help me with my assignment.
I have scrapped a lot of the pointless code that wasn’t needed and organised it a little better and 2/3 of my outputs are outputting correctly.
Test 3 is not for some reason.
Test 3 :
Swim Times = 2 hrs 50 Mins 02 Secs
Bike Times = 9 hrs 20 Mins 53 Secs
Run Times = 6 hrs 42 Mins 59 Secs
Expected Output:
18hr 53min 54sec
Actual Output:
0hr 41min 38sec
I’m assuming the math is wrong somewhere, but I can’t seem to see it.
If someone could help me figure this out and find out why I’m getting the wrong output that would be great.
ALSO, I am aware I can use loops and other things, however the assignment I’m doing DOES NOT permit me to use them
Thanks in advance.
You are doing all you math in 16-bit integers. The largest value a 16-bit integer can store is 32767. You are multiplying your hour values by 3600. For value of hour greater than 9.1 you will get an integer overflow and some of your values will turn negative.
If you switch the time values to "unsigned int" you could store up to 65535. Then your values won't overflow until you reach 18.2 hours. If you want to measure the time in seconds and you anticipate totals greater than 18.2 hours you should switch everything to "unsigned long".
