hii every budy ... after amonth of intensive working with arduino i manged to get several devices working togther ... my project is mesuring distance between 2 arduinos using gps and xbee in both sides ... but im new arduino user so im sure u can give me a hints to enhance my code...
here is my receiver code /// the transmitter is sending float variables with packet markers {} ()
#include <NewSoftSerial.h>
#include <TinyGPS.h>
#include<math.h>
#define RXPIN 2
#define TXPIN 3
#define GPSBAUD 4800
TinyGPS gps;
boolean started = false;
boolean ended = false;char inData[24]; // Size as appropriate
byte index = 0;float calc_dist(float flat1, float flon1, float flat2, float flon2);// function for calc. distance given lat&lon for 2 points on earth
float getlat2();// getting lat from another arduino
float getlon2();//getting lon from another arduino#define SOP '{'// start of packet
#define EOP '}'//end of packetNewSoftSerial uart_gps(RXPIN, TXPIN);
float getgpslat(TinyGPS &gps);
float getgpslon(TinyGPS &gps);
Serial.begin(9600);// for xbee
uart_gps.begin(GPSBAUD); // setup sketch for data output speed of GPS module im using em406a}
float lat1,lat2,lon1,lon2,d;
while(uart_gps.available()>0) // While there is data on the RX pin...
int c = uart_gps.read(); // load the data into a variable...
if(gps.encode(c)) // if there is a new valid sentence...
{lat1=getgpslat(gps);//getting my lat
lat2=getlat2();// getting another arduino latlon1=getgpslon(gps);
lon2=getlon2();
delay(5000);
d= calc_dist(lat1,lon1,lat2,lon2);
Serial.print(d,5);
}float getgpslat(TinyGPS &gps)
{float latitude, longitude;
gps.f_get_position(&latitude, &longitude);
return latitude;
return longitude;
float getlat2()
while(Serial.available() > 0)
char inChar = Serial.read();
if(inChar == SOP)
started = true;
index = 0;
inData[index] = '\0';
else if(inChar == EOP)
ended = true;
if(index < 24-1) // Array size
inData[index++] = inChar;
}if(started && ended)
float lat1= atof(inData);return lat1;
float getlon2()
if(inChar == '(')
started = true;
index = 0;
else if(inChar == ')')
ended = true;
float lat2= atof(inData);return lat2;
}float calc_dist(float flat1, float flon1, float flat2, float flon2)
float dist_calc=0;
float dist_calc2=0;
float diflat=0;
float diflon=0;//I've to spplit all the calculation in several steps. If i try to do it in a single line the arduino will explode.
diflat=radians(flat2-flat1);
flat1=radians(flat1);
flat2=radians(flat2);
diflon=radians((flon2)-(flon1));dist_calc = (sin(diflat/2.0)sin(diflat/2.0));
dist_calc2= cos(flat1);
dist_calc2=cos(flat2);
dist_calc2*=sin(diflon/2.0);
dist_calc +=dist_calc2;dist_calc=(2*atan2(sqrt(dist_calc),sqrt(1.0-dist_calc)));
dist_calc*=6371000.0; //Converting to meters
// Serial.println(dist_calc);
return dist_calc;
