Alphanumeric keypad on TFT screen.
I need help. I want to use my keypad as an alphanumeric keypad and display it to the tft. I'm using the 3.2" TFT HX8357 LCD shield for Arduino Mega, and it isn't touchscreen btw.
I have this library but i can't understand it, the comment didn't really help me. Where should i put the setCursor so it'll erase the previous char? So if i press 2 again within 500ms it'll print 'A' in the same place and so on..
Need help the algorithm, or another library if anybody have it. Thanks!
#include <Keypad.h>
#include <String.h>
#include <TFT_HX8357.h>
TFT_HX8357 tft = TFT_HX8357();
//change following according to the keypad
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
byte rowPins[ROWS] = {7, 6, 5, 4}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {11, 10, 9, 8}; //connect to the column pinouts of the keypad
//assign number to the each key as shwon in below. since I am using 4x4 keypad hence numbers are from 0 to 15.
//MAKE SURE NUMBERING STARTS FROM 0 AND THERE IS NO NUMBERS ARE MISSING BETWEEN TWO NUMBERS!
char keys[ROWS][COLS] = {
    { 0,1,2,3 },
    { 4,5,6,7 },
    { 8,9,10,11},
    { 12,13,14,15}
 * Following array is used to assign characters and strings to the keys
 * 1) If you want to assign character to the keys then assign characters without space for e.g. '2abcABC'
 * 2) If you want to assign strings to keys then assign strings with '-' at the end for e.g. 'caps-small-no'
 * 3) If you want to assign both character and string then you can do it like 'A-a-hello-*-ok'. by adding '-' between characters and strings.
char* keyStringArray[20] = {
  "1.*#", "2abcABC", "3defDEF", "caps-small-no-",
  "4ghiGHI", "5jklJKL", "6mnoMNO", "up-",
  "7pqrsPQRS", "8tuvTUV", "9wxyzWXYZ", "down-",
  "left-", "0 ", "right-", "Enter-"
 * if you want to assign long press button functionality to any button then assign function using following array.
 * make sure to assign to appropriate button.
char* longPressKeyStringArray[20] = {
  "cancel", "", "menu", "zero"
//999 to indicate end of array
int alphaKeys[] = {1, 2, 4, 5, 6, 8, 9, 10, 999};  //add numbers of keys which are going to represent alphabet.
int singlePressKeyButtons[] = {0, 1, 2, 4, 5, 6, 8, 9, 10, 13, 999};  //add numbers of keys which are going to cycle through characters
int singlePressCmdButtons[] = {3, 7, 11, 12, 14, 15, 999}; //add numbers of keys which are going to cycle through strings
int longPressCmdButtons[] = {12, 14, 15, 999};  //add numbers of characters which are going to have long press button functionality
static byte kpadState;  //to store key state i.e. PRESSED, HOLD or RELEASED
char textMode[10] = "no";  //initial text mode, no = numbers, caps = capital alphabet, small = small alphabet
byte keyState = 0;  //0 = released, 1 = hold
int textModeKey = 3; //assign textmode key number to this variable.
char valueToSend[50] = {}; //it will store final value to send to the serial monitor.
unsigned long TimeInMillis;
//initialize the keypad
Keypad key_pad(makeKeymap(keys), rowPins, colPins, sizeof(rowPins), sizeof(colPins));
//follwoing array will used to store the number of times the key is pressed which will help to cycle through characters or strings.
int keyCounterArray[16] = {0};
  tft.init();
  tft.setRotation(1);
  tft.fillScreen(0x00000);
  tft.setCursor(180, 10, 4);
  tft.setTextColor(TFT_WHITE,TFT_BLACK);  tft.setTextSize(1);
  tft.println("Library List");
  key_pad.begin(makeKeymap(keys));
  key_pad.addEventListener(keypadEvent);
  //key_pad.setDebounceTime(100);
  key_pad.setHoldTime(2000);
  TimeInMillis = millis();
  tft.setTextFont(4);
  int val = key_pad.getKey();
//minimum time in milliseconds required between two key press to cycle through values
int TimeDiffBtwnKeyPress = 1500;
//following function is used to cycle through characters
//startIndex and endIndex are used to cycle through particular part of character array. this is important because
//in 'caps' text mode we only want to cycle through capital letters, in 'small' text mode we only want to cycle through small letters etc.
void getKeyFromKeyPress(int keyVal, int beginIndex, int endIndex){
  char subString[50] = {};
  strncpy(subString, keyStringArray[keyVal] + beginIndex, endIndex - beginIndex);
  if((millis() - TimeInMillis) < TimeDiffBtwnKeyPress && strstr(subString, valueToSend) != NULL)
      keyCounterArray[keyVal]++;
  else{
    keyCounterArray[keyVal] = 0;
  if(keyCounterArray[keyVal] == strlen(subString))
  valueToSend[0] = subString[keyCounterArray[keyVal]];
  valueToSend[1] = '\0';
  tft.print(valueToSend);
  Serial.println(valueToSend);
//following function is used to cycle through strings
void getCommandFromKeyPress(int keyVal){
  int counterLimit = 0;
  int i = 0, j = 0, k = 0;
  while(keyStringArray[keyVal][i] != '\0'){
    if(keyStringArray[keyVal][i] == '-')
      counterLimit++;
    i++;
  if((millis() - TimeInMillis) < TimeDiffBtwnKeyPress && strstr(keyStringArray[keyVal], valueToSend) != NULL && valueToSend != "")
  else{
  if(keyCounterArray[keyVal] == counterLimit)
  char cmds[10][10] = {0};
  while(keyStringArray[keyVal][k] != '\0'){
    while(keyStringArray[keyVal][k] != '-'){
      cmds[i][j] = keyStringArray[keyVal][k];
      k++; j++;
    i++; k++; j = 0;
  strcpy(valueToSend, cmds[keyCounterArray[keyVal]]);
//following function is used for long press functionality
void getCommandFormLongKeyPress(int keyVal){
  if(longPressKeyStringArray[keyVal] != ""){
    strcpy(valueToSend, longPressKeyStringArray[keyVal]);
void keypadEvent(KeypadEvent key){
  kpadState = key_pad.getState();
  int keyVal = key;
  switch(kpadState){
    case PRESSED:
    case HOLD:
      if(isValueInArray(keyVal, longPressCmdButtons)){
        keyState = 1;
        getCommandFormLongKeyPress(keyVal);
    case RELEASED:
      if(keyState == 1)
        keyState = 0;
      else if(isValueInArray(keyVal, singlePressCmdButtons))
        getCommandFromKeyPress(keyVal);
      //following part of code will use startIndex and endIndex of particular part of character array to cycle through on that much part.
      else if(isValueInArray(keyVal, alphaKeys) && strcmp(textMode, "caps") == 0)
        getKeyFromKeyPress(keyVal, (strlen(keyStringArray[keyVal])/2) + 1, strlen(keyStringArray[keyVal]));
      else if(isValueInArray(keyVal, alphaKeys) && strcmp(textMode, "small") == 0)
        getKeyFromKeyPress(keyVal, 1, strlen(keyStringArray[keyVal])/2 + 1);
      else if(isValueInArray(keyVal, singlePressKeyButtons) && strcmp(textMode, "no") == 0)
        getKeyFromKeyPress(keyVal, 0, 1);
      else if(isValueInArray(keyVal, singlePressKeyButtons))
        getKeyFromKeyPress(keyVal, 0, strlen(keyStringArray[keyVal]));
      if(keyVal == textModeKey)
        strcpy(textMode, valueToSend);
bool isValueInArray(int val, int *arr){
    int i = 0;
    while (arr[i] != 999) {
        if (arr[i] == val)
            return true;
        i++;
    return false;
  tft.setTextFont(4);
How many times do you need to set the text color? How many times do you need to set the text font? How many times do you need to get the key that is pressed, and store the value in the wrong type, doing nothing with the value?
How about one, one, and none?
You should put the call before the call to tft.print(), obviously. As to the values to pass to setCursor(), you need to keep track of what row and column you last printed to, so you can advance or backspace as needed.
