I have found plenty of documentation on how to put a Synaptics touchpad in absolute positioning mode over PS/2.
For ALPS devices, however, I just barely was able to pick the hint* while googling, but there seems to be no documentation on how to interpret the data bytes received in this mode.
I have tried interpreting them myself (via binary output on the serial console), but i can't quite figure it out. Does anybody here have experience with ALPS touchpads?
I have tried using Synaptics' data format, but it appears to be different.
help is greatly appreciated!
if anyone's interested: to put an ALPS touchpad into absolute mode, send four disable commands 0xF5 before the enable command 0xF4...
I realize this is a rather old post, but for those who came here from google: you can find some information in the linux kernel module for this device.
and now i am receiving absolute values, but only if i'm tapping or moving my finger a little bit on the pad, so if i only put my finger down to one place i won't get the values instantly.. pehaps there is anything i can change?!?
well, but for now, thats what i wanted, thanks for posting this hint, even if that wasn't the working for you.
well that was not 100% correct, because there was something missing, you shouldn’t use 0xeb for “give me data”.
I’m pretty close now. Now I only have to combine the raw bytes…
because up to now its like having two values for X and for Y.
the first x is the detailed one, going from 0 to 128. the second one is the “multiplicator” from 8 to 56, i have to combine them, but I don’t know how. But I can manage it in the software afterwards, so for me this code is ok.
have a look:
#include <ps2.h>
* an arduino sketch to interface with a ps/2 trackpad.
* based on the ps2_mouse.pde from Arduino playground converted to trackpad use by andreas brendle
* Pin 5 is the mouse data pin, pin 6 is the clock pin
* Feel free to use whatever pins are convenient.
PS2 mouse(6, 5);
* initialize the trackpad.
void mouse_init()
{ //put trackpad in Absolute mode: 4Disable 1Enable
mouse.write(0xF5); // Disable
mouse.write(0xF4); // Enable
mouse.read(); // ack byte
mouse.read(); // blank */
mouse.write(0x00f0); // poll mode
delayMicroseconds(100);
mouse_init();
Serial.println("ok");
* get a reading from the pad and report it back to the
* host via the serial line.
char mstat;
char mx;
char mx2;
char my;
char my2;
char mz;
/* get a reading from the mouse */
mouse.write(0x0f); // give me data! 0xeb not working
mouse.read(); // ignore ack
mouse.read();
mx = mouse.read();
mx2 = mouse.read();
my = mouse.read();
my2 = mouse.read();
mz = mouse.read();
/* send the data back up */
// Serial.print(mstat, BIN);
Serial.print("<x>");
Serial.print(mx, DEC);
Serial.print("</x>\t<x2>");
Serial.print(mx2, DEC);
Serial.print("</x2>");
Serial.print("\t<y>");
Serial.print(my, DEC);
Serial.print("</y>\t<y2>");
Serial.print(my2, DEC);
Serial.print("</y2>");
Serial.print("\t<z>");
Serial.print(mz, DEC);
Serial.println("</z>");
// delay(20); /* twiddle */
