Alright I have had enough!
I am trying to ceate a code that slows down pin 9 (m2f) gradually has the sensor’s value increases and stops pin 9 at 400.
This is what I got so far:
 int m1r=2;
int m1l=3;
int m2f=9;
int m2b=11;
const int sensorMin = 200;
const int threshold = 400;
  pinMode(m1r, OUTPUT);
    pinMode(m1l, OUTPUT);
     pinMode(m2f, OUTPUT);
      pinMode(m2b, OUTPUT);
  // read the sensor:
    int analogValue = analogRead(0);
    switch (analogValue) {
    case 1: 'sensorMin<analogValue<threshold' ;
    { for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=5) {
    analogWrite(m2f, fadeValue);
    delay(300);
    case 2: 'analogValue > threshold';
   {  digitalWrite(m2b,LOW);
   digitalWrite(m2f,LOW);
   digitalWrite(m1r,HIGH);
   digitalWrite(m1l,HIGH);
    default:
  digitalWrite(m2b,HIGH);
But IT DOESN"T WORK PROPERLY. Pin 9 remains on LOW(On LOW the motor activates)
Thanks
What is this:
case 1: 'sensorMin<analogValue<threshold' ; ?
The switch statement can only be used when the value or conditional resolves to specific values (the case values).
You want a series of if/else if/else statements, and you want to read up on how to use the if statement.
    case 1:[glow] 'sensorMin<analogValue<threshold' ; [/glow]
What the highlighted text supposed to mean? A new way of entering a comment that I was not aware of? Gives me a compile error.
analogRead returns a value in the range 0 - 1023. It may be hard to hit 1 or 2. Have you tried to print analogValue?
Really? What version are you running? (there's nothing really wrong with putting in a multi-character constant here, but it won't actually do anything)
0018 with warnings == errors, as described in this thread: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1278712207/11
Catches plenty of weird mistakes.
I would argue that it isn't an error - not what was wanted or intended, but perfectly allowable by the rules of the language. enabling warnings-as-errors doesn't actually show the error here, which is a lack of understanding of conditionals.
I set warning==errors merely to ensure that the IDE will stop and indicate the suspicious line.
