Alternating Pattern and user input in memory game
I have been trying to create a memory game (kind of like simon) on my arduino, using a 3x3 LED grid and a corresponding grid of switches. My problem is with my code. I have been able to create code to generate a random pattern of 5 LEDs for the player to copy, I have been able to create code to translate the player's inputs into LED flashes on the grid, and I'm (pretty sure) I have created code to remember the generated pattern and the player's inputs and compare them to check for a success or failure.
BUT
The program always only does one function or the other.
The sequence of events should be:
  1. program generates 5 random LED flashes, and remembers them
  2. waits for player input
  3. player presses 5 buttons, i.e lights 5 LEDs in an attempt to copy the pattern
  4. program checks generated pattern against user input
  5. program indicates if user is correct or not, (i.e. via a flash of all LEDs or something like that, or simply playing a new pattern. the specific behavior is not important)
The problem is step 2 never seems to happen; my code either just generates patterns, or if I try to rearrange things, just allows input.
I have never programmed before, and this is pretty much my first arduino program, so I'm quite the novice. Any help of any sort is greatly welcome!
(I also apologize for the ugliness of my code. Like I said, I'm new to this, and am not very good with formatting)
Code:
#include <Keypad.h>            //use Keypad library
const byte rows = 3;           //three rows
const byte cols = 3;           //three columns
char keys[rows][cols] =
  {'1','2','3'  },             //touchpad grid
  {'4','5','6'  },
  {'7','8','9'  }
byte rowPins[rows] = {
  2, 3, 4}; //the row pin of the touchpad
byte colPins[cols] = {
  5, 6, 7}; // column pin of the touchpad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, rows, cols );
int ledCol1 = 8;      //identify pins
int ledCol2 = 9;
int ledCol3 = 10;
int ledRow1 = 11;
int ledRow2 = 12;
int ledRow3 = 13;
int memoryRow[5];
int memoryCol[5];
int pressedRow[5];
int pressedCol[5];
  pinMode(ledCol1, OUTPUT);    //define pin states,
  pinMode(ledCol2, OUTPUT);
  pinMode(ledCol3, OUTPUT);
  pinMode(ledRow1, OUTPUT);
  pinMode(ledRow2, OUTPUT);
  pinMode(ledRow3, OUTPUT);
  digitalWrite (ledCol1, LOW);
  digitalWrite (ledCol2, LOW);
  digitalWrite (ledCol3, LOW);
  digitalWrite (ledRow1, LOW);
  digitalWrite (ledRow2, LOW);
  digitalWrite (ledRow3, LOW);
  memoryFunc();
  for(int t=0; t<5; t++)
Serial.println(memoryCol[t]);
//Serial.println(memoryRow[t]);
  for(int x=0; x<5; x++)
    playerFunc(x);
///////////memory
void memoryFunc()
  for(int i=0; i<5; i++)
    memoryRow[i]=random(11, 14);
    memoryCol[i]=random(8, 11);
    lightMemory(i);
  digitalWrite (ledCol1, LOW);    //All Off
///////////mem inf
int lightMemory(int j)
  if(memoryRow[j]==11 && memoryCol[j]==8)
    digitalWrite (ledCol1, HIGH);    //light LED 1
    digitalWrite (ledRow2, HIGH);
    digitalWrite (ledRow3, HIGH);
  else if(memoryRow[j]==12 && memoryCol[j]==8)
    digitalWrite (ledCol1, LOW);    //light LED 2
    digitalWrite (ledCol2, HIGH);
  else if(memoryRow[j]==13 && memoryCol[j]==8)
    digitalWrite (ledCol1, LOW);    //light LED 3
    digitalWrite (ledCol3, HIGH);
  else if(memoryRow[j]==11 && memoryCol[j]==9)
    digitalWrite (ledCol1, HIGH);    //light LED 4
    digitalWrite (ledRow1, HIGH);
  else if(memoryRow[j]==12 && memoryCol[j]==9)
    digitalWrite (ledCol1, LOW);    //light LED 5
  else if(memoryRow[j]==13 && memoryCol[j]==9)
    digitalWrite (ledCol1, LOW);    //light LED 6
  else if(memoryRow[j]==11 && memoryCol[j]==10)
    digitalWrite (ledCol1, HIGH);    //light LED 7
  else if(memoryRow[j]==12 && memoryCol[j]==10)
    digitalWrite (ledCol1, LOW);    //light LED 8
  else if(memoryRow[j]==13 && memoryCol[j]==10)
    digitalWrite (ledCol1, LOW);    //light LED 9
///////////input
void playerFunc(int z)
  char key = keypad.getKey();    //keypad detection
  Serial.println(key);
  if (key == '1')
    pressedRow[z]=11;
    pressedCol[z]=8;
    delay (220);                     //wait 220
    int off1 = off();                //send to off
  else if (key == '2')
    pressedRow[z]=12;
    pressedCol[z]=8;
  else if (key == '3')
    pressedRow[z]=13;
    pressedCol[z]=8;
  else if (key == '4')
    pressedRow[z]=11;
    pressedCol[z]=9;
  else if (key == '5')
    pressedRow[z]=12;
    pressedCol[z]=9;
  else if (key == '6')
    pressedRow[z]=13;
    pressedCol[z]=9;
  else if (key == '7')
    pressedRow[z]=11;
    pressedCol[z]=10;
  else if (key == '8')
    pressedRow[z]=12;
    pressedCol[z]=10;
    int off1 = off();                //send to off function
  else if (key == '9')
    pressedRow[z]=13;
    pressedCol[z]=10;
int off()                      //function turns LEDs off
  digitalWrite (ledCol1, LOW);    //light NONE
Thanks!
int ledCol1 = 8;      //define variables
These are not...variables.
Can I suggest you stop, slow down, and break your problem down into simpler stages, deug them all separately, and then bring them together?
Thanks for your quick response,
I apologize again for how terribly everything must be commented/arranged. Individually, each piece seems to work fine.
touchpad (input) code:
#include <Keypad.h>            //use Keypad library from Arduino.cc
  {'4','5','6'  },
  {'7','8','9'  }
  2, 3, 4}; //connect to the row pinouts of the touchpad
  5, 6, 7}; //connect to the column pinouts of the touchpad
int ledCol2 = 9;
int ledCol3 = 10;
int ledRow7 = 11;
int ledRow8 = 12;
int ledRow9 = 13;
  pinMode(ledCol1, OUTPUT);    //define pin states, HIGH/LOW levels
  pinMode(ledRow7, OUTPUT);
  pinMode(ledRow8, OUTPUT);
  pinMode(ledRow9, OUTPUT);
  digitalWrite (ledRow7, LOW);
  digitalWrite (ledRow8, LOW);
  if (key == '1')
    digitalWrite (ledRow8, HIGH);
    digitalWrite (ledRow9, HIGH);
    delay (220);                     //wait 220 milliseconds
    digitalWrite (ledRow7, HIGH);
    digitalWrite (ledRow9, LOW);
For generating a random pattern, see the first section of the original code
I think my problem is that I can't get the pieces to play nicely with each other, to go in an orderly fashion from one step to the other. Any suggestions for how I might be able to do this?
