I am looking for an IDE that allows me to put breakpoints into the code and examine variables. This is very standard in all of the environments I have worked with in the past, but I have no idea if this is even possible with Arduino platforms.
Are there any environments that support active debugging? Baring that, what are the best alternatives to the rather limited Arduino IDE?
Your post is going to hurt peoples feeling The ide is not limited it's just what it is you can watch the code with the serial monitor just have it print it out. I don't see not having breakpoints as a limitation.
Code runs from a to B then print it out works just as good and is in real time.
The limitation is not the IDE, it is the hardware.
The basic Arduino boards do not support any debugging or emulation. The basic AVR used only has a very limited hardware debugger (DebugWIRE?) which requires giving up the RESET pin.
For proper debugging support, you might want to look at the Arduino Zero. It's supports Atmel's Design Studio and features the first Arduino board with an on-board debugger.
rhj4:
It's not, but more to the point, it is not efficient.
The sort of real-time things for which most Arduinox are used, are clearly different from what you have been using so far. "Crash and burn" debugging is quite effective.
Looks like it is adding a monitor to the sketch and emulating a hardware debugger.
While clever, it does have a major drawback: it alters the program's behavior. Adding serial commands, timed breakpoints, etc may affect timing and available RAM on your project (2K isn't much to work with). Very possible you'll go to debug a problem, but only create more problems in the process.
The upside is, for simple programs, you do get back much of the functionality of a true hardware debugger.
