Alternative IR Sensor Module
Hello, I'm trying to do a project about Automatic Room Light Controller with this guide https://circuitdigest.com/microcontroller-projects/automatic-room-light-controller-with-bidirectional-visitor-counter-using-arduino
However, I can't find the same IR sensor module used in the first project and planning to use another kind of IR sensor. Will it still work if I use the same code provided by the first project?
Below is the code and I've attached the photo for the IR sensor.
Thank you.
#include<LiquidCrystal.h>
LiquidCrystal lcd(13,12,11,10,9,8);
#define in 14
#define out 19
#define relay 2
int count=0;
void IN()
    count++;
    lcd.clear();
    lcd.print("Person In Room:");
    lcd.setCursor(0,1);
    lcd.print(count);
void OUT()
  count--;
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print(count);
  lcd.begin(16,2);
  lcd.print("Visitor Counter");
  delay(2000);
  pinMode(in, INPUT);
  pinMode(out, INPUT);
  pinMode(relay, OUTPUT);
  lcd.clear();
  lcd.setCursor(0,1);
  lcd.print(count);
  if(digitalRead(in))
  IN();
  if(digitalRead(out))
  OUT();
  if(count<=0)
    lcd.clear();
    digitalWrite(relay, LOW);
    lcd.clear();
    lcd.print("Nobody In Room");
    lcd.setCursor(0,1);
    lcd.print("Light Is Off");
    delay(200);
    digitalWrite(relay, HIGH);
Here's those pics, for simplicity:
Are those pics the sensor you need ot the one you can get or what?
12Stepper:
Thank you, I didn't know how to put it that way.
The first pic is the one that was used in the project guide I'm trying to work on, however, I can't find it.
The second pic is the one that I plan to using as an alternative.
My question is, will the code still work if I change the IR sensor module? If not, where in the code is that?
Thank you, again.
The code simply digitalRead()s the pins to which the sensors are attached, and the proposed ones look like they have a simple digital output so should be ok.
The diiference may be in whether the proposed sensor works with the same logic as the originals.
In the code, this:
if(digitalRead(in))
... is short-hand for:
if(digitalRead(in)==HIGH)
That means the output of that sensor goes high when it senses something. Some sensors work the other way round, going low when sensing something; I have one like that. It depends on the way it's manufactured.
It's easy to check though. Just apply power to the pins and measure the voltage across out and ground when it's sensing something and when it's clear. If it's logic is upside down, you will just change the line:
if(digitalRead(in))
... which remember is really:
... to:
if(digitalRead(in)==LOW)
(There may need to be further discussion on pullup and pulldown resistors but that can probably wait.)
12Stepper:
In the code, this:
if(digitalRead(in))
if(digitalRead(in))
... to:
Okay, thanks. From what I've understood, it's supposed to work just fine, right? Also, if the logic is reversed when I used the proposed sensor, I just need to replace the code with ... LOW.
Planning to work on it this week, hope it ends well.
Yeah ... get it working to do it as the link says, and then I think you may uncover some shortcomings in the whole premise of trying to use two sensors to count occupancy like that.
But that's next week's discussion :wink:
By the way, since a sensor like that is just off or on, high or low, you can test your code with a button. pinMode() as input pullup, and press to pretend someone's in front of the sensor.
12Stepper:
I was hoping that there will be no shortcomings :frowning: since the deadline's on 6 already. And need to do a report on it as well.
12Stepper:
Sorry, I am lost starting at testing the code with a button.
JinRar:
The shortcomings are something you can put in the report, with perhaps some suggestions for improvement.
JinRar:
When the sensor is clear, its output is at a level (high or low) as discussed. When it's obstructed, the output's at the other level (low or high).
A button's exactly the same: unpressed it's high or low depending how it's wired; pressed it's at the other lever, low or high.
So in the normal state, the unobstructed sensor is the same as an unpressed button; when active, the obstructed sensor is the same as a pressed button.
You could mimic someone walking in front of the sensor, by pushing the button for the time it takes them to enter and leave the sensor's "zone".
(I just did that with the code you linked, adjusted for the way my buttons are wired.)
12Stepper:
I see, I thought it would fail to work at some point during the course or something missing that won't allow the project to work. Thanks, I could really put it in the recommendation part.
12Stepper:
Oh, its kind of similar to what the man did in the video sample from the link.
Hello, sorry for bringing this up again.
We did the project but somehow the IR sensor seems to be not in sync with the LCD display. The display continues to count even though no object passes through. Is the sensor the problem, the LCD, or the code?
Also, if I may, where can I ask for some help regarding signal conditioning using the datasheet? The technical report requires us to do it (signal conditioning) but we have done something but don't know if it was correct.
The logic of your sensors may be reversed from the guy's (see post #4).
