Alternative solutions to cup/propellers/ultrasonic wind sensors?
I am planing to measure the wind speed (and direction, if possible).
The cup anemometers and propellers anemometers are not suitable for low speed (below 2-3 m/s) while the ultrasonic ones have some esoteric descriton, which I do not trust:
http://www.diva-portal.org/smash/get/diva2:425655/FULLTEXT01.pdfhttp://www.diva-portal.org/smash/get/diva2:425655/FULLTEXT01.pdf
Precision is not an issue, but cost and simplicity - yes!
This will be an extension module to the environmental portable multi-sensor which I almost finished in prototype.
Question is: is there any low-cost wind sensor (up to 20 USD) that can communicate with the Arduino nano, except the cup/propellers ones?
And another challenge: is anyoane aware about attempts to hack an existing sensor to persuade it to measure wind speed? I am thinking to a pressure one or some based on Bernoulli (Pitot tubes ?).
Thank you!
Another non-moving one is the thermal, or hot wire anemometer.
Leo..
Looks promising. Do you think it can be made as a DiY project?
Stephen Woodward has published a series of articles on hot wire anemometers, Google came up with the following https://www.edn.com/design/analog/4345837/Transistor-linearly-digitizes-airflow and
https://www.edn.com/design/other/4349976/EDN--03-14-96-Self-heated-transistor-digitizes-airflo are 2 that came up quickly. If the pictures in the articles don't come up when you click make EDN aware & they will fix the issue.
Bill
PS the second reference is 1 I've used at times
Here's another one which uses 3 transistors to generate wind direction & speed.
Here's the article in zip format with illustrations
http://microcontrollers.2385.n7.nabble.com/Vector-anemometer-td40902.html
Bill
The transistors are more rugged than exposed hot wire filaments but having more thermal mass take longer to respond
I've often thought of a wind force meter using a sphere of about, say, 20 cm diameter tensioned between 2 strain gauges, 1 for N/S, 1 for E/W but don't have the machine working tools to pursue it.
I would use three gauges. Saves one sensor, but should also make balancing easier: compare trying to balance a three-legged table vs. a four-legged table on a rough floor, and three sensors is enough to calculate all directions based on the force ratio between them.
That transistor idea is interesting. Trying to get at least a basic understanding of what's going on there but it's not easy.
My anemometer uses a bar magnet turning over a reed switch and driven by cups to catch the air. It registers correctly less than 1 MPH. I count the number of switch closures for 1 second.
Paul
Nonsense. My cup anemometer spins in the slightest breath of wind, and is accurate at 1 m/s.
It can even be used to accurately measure walking speed.
@jremington - depends on the brand and type. But the most Ive seen at a reasonable price starts measuring from 2 m/s. Construction constraints at consumer end apply. Marketing is also particularly effective these days.
There is also an accuracy problem at low speeds around the inferior limit.
The only way to make sure about this is to calibrate the anemometer using a meteo certified one. In my case, that is beyond the practical aim.
Think to a practical problem as well: you are in the mountains with a backpack of different instruments, food, water. Carrying a cup anemometer or a costly propeller one is not appealing.
falexandru:
I got mine at a swap meet for 10 US dollars.
In wonder why you even bothered to make the original post, now that you have dismissed all the suggestions as not being practical.
Paul
Don't forget that the required high quality instrumentation has to cost less than a cup of cappuccino!
I posted to find out whether there is any wind measurement solution that I am not aware and that can be adopted in the hobby environment. I got at least 2 valuable ideas and suggestions. I do not reject anything, since any opinion is relevant and I just wanted to stress the circumstances for people to understand me better.
outsider:
Spheres may shed vortices, which might be a problem.
