Alternative Temparature sensor / Code problem
Good Day,
I have used Arduino and ESP8266 in this project. I am able to control the GPIO thru internet. I am also able to monitor my room temperature using a LM35 sensor but there are some spikes in the graph. I dont know if the problem is in the LM35 sensor itself or in the code.
Here is the Web Generated code for the Arduiono and ESP8266.
//-- For ESP8266 Lua code.
–visit www.iot-ph.com for more info
–for tutorials http://thinkingparts.blogspot.com/2015/08/home-automation-diy-version-internet_23.html
–This code is for your ESP8266 WIFI Module
–Use Lualoader in uploading your code
–Values to be changed
ssid=“Your WIFI Name” --you wifi name
sspwd=“Your WIFI Password” --your wifi password
–Also replace “YOURDEVICEIDHERE” below with your device ID
–Variables
count=0
–set the WIFI Mode
wifi.setmode(wifi.STATIONAP)
wifi.setmode(wifi.STATION)
wifi.sta.config(ssid,sspwd)
function internet()
uart.on(“data”, “\r”,
  • function(data)*
  • print(data)*
  • if (data==nil) then*
  • data=“s1=9&s2=9&s3=9&a1=999&a2=999&a3=999 HTTP/1.1\r\n”*
  • end*
  • count=count+1*
  • if count==250 then*
  • count = 0*
  • end*
  • s1=(string.sub(data,string.find(data,“s1=”)+0,string.find(data," ")+0)) *
  • conn=net.createConnection(net.TCP, 0)*
  • conn:on(“connection”,function(conn, payload)*
  • conn:send(“GET /account/diy_cmd_sts.php?id=YOURDEVICEIDHERE&uid=242&c1=1&c2=1&c3=1&”…(s1)…*
  • “HTTP/1.1\r\n”…*
  • “Host: iot-ph.com\r\n”…*
    _ “Accept: /\r\n”…_
  • “User-Agent: Mozilla/4.0 (compatible; esp8266 Lua;)”…*
  • “\r\n\r\n”)*
  • end)*
  • conn:on(“receive”, function(conn, payload)*
  • conn:close()*
  • payload1=(string.sub(payload,string.find(payload,“cmd1=”)+0,string.find(payload,“cmd1=”)+18))*
  • print(“X”…payload1…“Y”) *
  • –print(“s1”…s1) *
  • end)*
  • conn:connect(80,‘iot-ph.com’)*
  • if data==“quit\r” then*
  • uart.on(“data”)*
  • end*
  • end, 0)*
  • tmr.delay(1000000)*
  • data=0*
  • tmr.alarm(1,4000,1,internet)*
    end
    internet()
//–For Arduino Code
// —THIS IS FOR ARDUINO
//For more details visit www.iot-ph.com
//For tutorials visit http://thinkingparts.blogspot.com/2015/08/home-automation-diy-version-internet_23.html
#include <SoftwareSerial.h>
String inData="";
int count=0;
String cmd1, cmd2, cmd3;
String d;
String s1, s2, s3;
String a1, a2, a3;
int sen1, sen2, sen3;
int pinA = 2;
int pinB = 4;
int pinC = 6;
int read1 = 3;
int read2 = 5;
int read3 = 7;
SoftwareSerial mySerial(10, 11); // RX, TX
*void setup() *
  • pinMode(pinA,OUTPUT);*
  • pinMode(pinB,OUTPUT);*
  • pinMode(pinC,OUTPUT);*
  • pinMode(read1,INPUT);*
  • pinMode(read2,INPUT);*
  • pinMode(read3,INPUT);*
  • Serial.begin(9600);// Open serial communications and wait for port to open:*
  • while (!Serial) {// wait for serial port to connect. Needed for Leonardo only*
  • Serial.println(“www.iot-ph.com Arduino-ESP8266-01!”);*
  • mySerial.begin(9600);// set the data rate for the SoftwareSerial port*
    void loop() // run over and over
  • int count=0;*
  • int ok=0;*
  • if (mySerial.available())*
  • while (mySerial.available() > 0)*
  • count++;*
  • char received = mySerial.read();*
  • inData += received;*
  • if (received == ‘X’){*
  • inData = “”;*
  • count=0;*
  • ok=1;*
  • if ((count==18) && (ok==1))*
  • processString();*
  • processStatus();*
  • processSensors();*
  • processSend();*
  • if(!mySerial.available())*
  • if (d==""){//initialization value*
  • d=("s1=9&s2=9&s3=9&a1=1024&a2=1024&a3=1024 ");*
  • Serial.println(d);*
  • mySerial.println(d);//send data to ESP*
  • delay(5000);*
    void processString(){
  • cmd1=inData.substring(5,6);*
  • cmd2=inData.substring(11,12);*
  • cmd3=inData.substring(17,18); *
  • if(cmd1==“2”){*
  • digitalWrite(pinA,HIGH);*
  • else if(cmd1==“1”){*
  • digitalWrite(pinA,LOW);*
  • if(cmd2==“2”){*
  • digitalWrite(pinB,HIGH);*
  • else if(cmd2==“1”){*
  • digitalWrite(pinB,LOW);*
  • if(cmd3==“2”){*
  • digitalWrite(pinC,HIGH);*
  • else if(cmd3==“1”){*
  • digitalWrite(pinC,LOW);*
    void processStatus(){
  • if(digitalRead(read1) == HIGH){*
  • s1=“2”;*
  • else{*
  • s1=“1”;*
  • if(digitalRead(read2) == HIGH){*
  • s2=“2”;*
  • else{*
  • s2=“1”;*
  • if(digitalRead(read3) == HIGH){*
  • s3=“2”;*
  • else{*
  • s3=“1”;*
    void processSensors(){
  • sen1=analogRead(A1);*
  • sen2=analogRead(A2);*
  • sen3=analogRead(A3);*
  • a1 = String(sen1);*
  • a2 = String(sen2);*
  • a3 = String(sen3);*
    void processSend(){
  • d = “s1=” + s1;*
  • d += “&s2=” + s2;*
  • d += “&s3=” + s3;*
  • d += “&a1=” + a1;*
  • d += “&a2=” + a2;*
  • d += “&a3=” + a3;*
  • d += " ";*
the spike you are looking for is the value at 38° in the first picture ??? … that’s not an awfull spike !!
try to do a moving average … it will smooth you data
