Hi everybody,
I want to build some device which will play sound files in high quality (the final product would be some kind of drumbeat pedal, so 16-bit stereo WAV files would be the minimum requirement). The main processing unit will probably be an Arduino Uno R3, and I saw a lot of projects using it with the DFPlayer mini, but there are some limitations with the DFPlayer, the most important being that I need to be able to play at least 2 soundfiles simultaneously.
I searched for alternatives, found the WAV Trigger (WAV Trigger — Robertsonics) but it seems to be a bit of an overkill a lot pricier than the DFPlayer. Do you know any audio module alternatives to DFPlayer Mini and WAV Trigger which could play 2 to 4 soundfiles simultaneously in high quality?
Thanks in advance for the help!
Stochelo
