If anyone has any suggestions and can help please.
I am using a pro mini to produce 5 PWM outputs driving mosfets and a 5 phase stepper.
The final 6th PWM has to be at the same pre-scaler division.
The data sheet doesn't seem clear about how I can use this to generate an interrupt in my code which could serve as an alternative to millis() or delay() - at about 20 milliseconds.
I'd have to increment a counter each time the interrupt routine was called, waiting until it reached the time elapsed I wanted.
I could take a piece of wire from the PWM output to the pin 2 input, but it seems a bit crude and I'm sure this can be done more appropriately in software.
The final project purpose is driving a telescope at sidereal rate, using encoder feedback from the final axis to determine and correct the rate at which micro steps are produced.
I have split the project into stages.
I will eventually generate an accurate clock interrupt on pin 2 from a 32kHz crystal oscillator and divider.
For testing the microsteps, PWM frequencies and mosfet driver on the bench, I just want to put in a temporary code that steps through the PWM values at about 45 Hz.
Code here to confirm I am using all 3 Timers for PWM.
//set up test of fast PWM on 5 outputs
pinMode(6, OUTPUT);//controlled by Timer 0
pinMode(5, OUTPUT);//controlled by Timer 0
pinMode(9, OUTPUT);//controlled by Timer 1
pinMode(10, OUTPUT);//controlled by Timer 1
pinMode(11, OUTPUT);//controlled by Timer 2
pinMode(3, OUTPUT);//controlled by Timer 2
TCCR0A = _BV(COM0A1) | _BV(COM0B1) | _BV(WGM01) | _BV(WGM00);
TCCR0B = TCCR0B & B11111000 | B00000001; // set timer 0 divisor to 1 for PWM frequency of 62500.00 Hz
TCCR1A = _BV(COM1A1) | _BV(COM1B1) | _BV(WGM10) | _BV(WGM11);//Don't get this shift 1's from right _BV
TCCR1A = TCCR1A & B11111000 | B00000001; //8 bit Fast PWM this is duplicate code but now works
TCCR1B = TCCR1B & B11100111 | B00001000; //8 bit Fast PWM this is duplicate code but now works
TCCR1B = TCCR1B & B11111000 | B00000001; // set timer 1 divisor to 1 for PWM frequency of 31372.55 Hz
TCCR2A = _BV(COM2A1) | _BV(COM2B1) | _BV(WGM21) | _BV(WGM20);
TCCR2B = TCCR2B & B11111000 | B00000001; // set timer 2 divisor to 1 for PWM frequency of 31372.55 Hz
OCR2A = 180;
OCR2B = 50;
OCR1A = 180;
OCR1B = 50;
OCR0A = 180;
OCR0B = 50;
