My PIN 10 on Arduino UNO is not working . I'am trying to get a MFRC522 Reader to get to work with arduino . So how i can i reassign a new SS pin on the board???
That depends on what you are trying to do.
Simple SPI applications you only need to use a different output in.
Example:
// enable Slave Select
digitalWrite( 9, LOW);
// send test string
for (const char * p = "Fab" ; c = *p; p++)
SPI.transfer (c);
// disable Slave Select
digitalWrite( 9, HIGH);
For pin 5 use the above.
#include <SPI.h>
#include <MFRC522.h>
#include <Servo.h>
#define SS_PIN 10
#define RST_PIN 9
#define SERVO_PIN 3
Servo myservo;
#define ACCESS_DELAY 1000
#define DENIED_DELAY 1000
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
Serial.begin(9600); // Initiate a serial communication
SPI.begin(); // Initiate SPI bus
mfrc522.PCD_Init(); // Initiate MFRC522
myservo.attach(SERVO_PIN);
myservo.write( 0 );
delay(7500);
myservo.write( 0 );
Serial.println("Put your card to the reader...");
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
//Show UID on serial monitor
Serial.print("UID tag :");
String content= "";
byte letter;
for (byte i = 0; i < mfrc522.uid.size; i++)
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
content.concat(String(mfrc522.uid.uidByte[i], HEX));
Serial.print("Message : ");
content.toUpperCase();
if (content.substring(1) == "C5 68 AF AC") //change here the UID of the card
Serial.println("Authorized access");
myservo.write( 180 );
delay(7500);
myservo.write( 0 );
else {
Serial.println(" Access denied");
delay(DENIED_DELAY);
How can i add it to this code?
Did you try:
`MFRC522 mfrc522( 5, RST_PIN); // Create MFRC522 instance.`
replace
#define SS_PIN 10
with
constexpr byte SS_PIN {5}; // or any other pin you can can use
and keep the line
