Alternatively blink two leds
Hi everybody!
I am facing a problem regarding how to blink two leds using the millis() function. I have understood how the function works, but not how to apply it in this case.
The sketch itself has to do something very simple, but I can't wrap my head around this thing.
Essentially,the sketch has to:
-Turn one led on for 5 seconds
-Turn that same led off and wait 3 seconds
-Turn the other led on for 5 seconds
-Turn it off and wait 3 seconds
The cycle then repeats. Think of it as a motor that first rotates in one direction, then pauses for a little, turns in the other direction, pauses again and repeats the cycle over and over again.
The two leds NEVER have to blink together.
If anybody could help me to solve this problem I'd be extremely glad.
Have you looked at the blink without delay example program?
You could modify that very quickly to do exactly what you want
Yes I have, but I really don't know where to start.
Could you give me some advice?
Modify the simple "blink without delay" sketch to have a different on and off time for one led.
Declare two new variables --timeOn and timeOff. Then, at the end of the timed interval when the code enters the section to turn the led on or off, set the interval equal to the time you want. The value of interval will be alternating between the timeOff an the timeOn.
Once you get this far, adding the second led will be easy.
The demo Several Things at a Time is an extended example of BWoD and illustrates the use of millis() to manage timing. It may help with understanding the technique, and it blinks 3 LEDs.
...R
Mattia9914:
Here is some code for switching through a 16-second-cycle:
const byte ledPins[] = {2, 3};//declare pin numbers for two LEDs
unsigned long sequenceStartTime;
void setLeds()
  long time = millis() - sequenceStartTime;
  if (time < 5000)
    digitalWrite(ledPins[0], HIGH); //first LED ON during first 5 seconds in a sequence
    digitalWrite(ledPins[1], LOW);
  else if(time < 8000)
  digitalWrite(ledPins[0], LOW); //both LEDs OFF until half-time
  else if(time < 13000) // second LED ON
    digitalWrite(ledPins[1], HIGH);
  else if(time < 16000) // both LEDs off until end of sequence
  else sequenceStartTime = millis(); // each 16 seconds we start a new sequence
  pinMode(ledPins[0], OUTPUT);
  pinMode(ledPins[1], OUTPUT);
  setLeds();
What do you think?
Thanks jurs for the code! It worked perfectly. However, I am wondering if it is possible to just do a 8 second function and just tell the code to alternate the leds during the pause.
Mattia9914:
OK, I'll give it another try, here is the code for using 8-second sequences:
byte cycleCount;
  if (time < 5000)
    digitalWrite(ledPins[bitRead(cycleCount,0)], HIGH); //one of the  LEDs ON during first 5 seconds in  sequence
digitalWrite(ledPins[bitRead(cycleCount,0)], LOW); //same LED OFF in the same cycle
  else // count up the cycleCount
    cycleCount++;
    sequenceStartTime = millis(); // each 8 seconds we start a new sequence
That's the way how it should work:
I have a byte counter named cycleCount, which will count up by 1 each 8 seconds.
As it is a byte only, the counter will roll over from 255 to 0 after 256*8=2048 seconds.
The low-bit (0-bit) of the counter will decide which LED is to be switched in this 8-second-cycle.
If the 0-bit "bitRead(cycleCount,0)" is 0 then ledPins[0] will be switched in this cycle.
And if the 0-bit "bitRead(cycleCount,0)" is 1 then ledPins[1] will be switched in this cycle.
Does it work as intended?
Yes! It works great. I notice there is a pause at the begnning of the cyle though, but no huge issue.
