Alternatives for l293d
Hi, I just completed my first project( an object avoiding robot that use a UNO R3, l293d shield and ultrasonic sensor). I powered it with 3 9v batteries but eventually had to power it with my laptop. My hypothesis is that this is due to inefficiency in the motor driver, and use of trash batteries. Can you recommend any good motor drivers that fulfill the following criteria -
-> Available in Amazon in India
-> Runs 4 Bi-directional DC motors (Yellow TT motors 3-12V)
-> Not from Pololu or aliexpress
-> Complete module, not merely an IC
-> Cheap ( less than 500 INR)
Likely the little rectangulars (which are useless). Use better batteries.
I figured, but do I need to upgrade the motor shield or only the batteries. Like if I ideally had a proper set of batteries, would it work without a problem
The voltage made available to the motor will be 3V or so less than the supply voltage.
These things are used by many 'hobbyists' - they're adequate on that level even if they aren't the best of the best. Get a holder with capacity for 6-8 'AA' or 'C' cells.
@runaway_pancake Is there a rechargeable option, since replacing batteries often tends to go heavy on the wallet. I tried Li ion, but the first battery I ordered melted the charger, the second came without a charger, the charger I later ordered was so messed up that it did not charge the batteries after 3 to 4 hours
Did a quick search and came up with Zero that meet all your criteria.
You need to relax your requirements.
Try searching for TB6612FNG, DRV8833 or DRV8835
Yes, sure - it's voltage and mAh (milliamp-hours).
You recounted a list of difficulties. In Li-ion terms, you're looking for a '3S' and, I suppose, one that comes with a charger.
Another option is NiMH, available in 'AA', 'C' packages. Eneloop is a good brand, so is Amazon_Basic.
I use an L298N H-bridge Module along with a rechargeable Lithium-Ion battery(12v, 1200mAh) and it works fine, though the battery's output reduced to 11v over time and couldn't power the module. The Module works in 12v-24v range.
The module has most likely 16volt caps on Vmot, so about 12volt is the limit.
12volt is also in the danger zone for an Uno if you leave the V-in jumper on.
Leo..
Yes, I apologize for forgetting about that. Thank you for correcting me.
@runaway_pancake and @jollom could you provide any amazon links for the batteries you mentioned
Sure, here you go:Amazon.com: Tectra 12V RC Battery with Bare Leads, 2200mAh High Capacity Ni-MH 10 Cells Rechargeable Battery Pack for RC Car, RC Boat, RC Robot, RC Airplane, DIY and More : Toys & Games
@jollom thanks, but how would you recharge this. I don't think it comes with a charger
i just use a random 12v charger i have at home. Just make sure the battery dosen't heat up while charging and make sure voltage is same.
Is it available in India?
i dont think so.
