Hi !
Thanks for the reply's!
@ Krodal:
I wouldn't know how to get the Atmospheric Pressure.
If I write: Serial.print(Pressure);
It gives an error: error: 'Pressure' was not declared in this scope
@ Vanja and Robtillaart:
I've tried the code from the Pressure Sensors MS5611 MS5803...
First the normal code without changes:
The result:
PROM COEFFICIENTS ivan
Error reading PROM 1
0
0
0
0
0
0
Actual TEMP= 20.00 Actual PRESSURE= 0.00
RAW Temp D2= 4294967295 RAW Pressure D1= 4294967295
C1 = 0
C2 = 0
C3 = 0
C4 = 0
C5 = 0
C6 = 0
C1 = 0
C2 = 0
C3 = 0
C4 = 0
C5 = 0
C6 = 0
C1 = 0
C2 = 0
C3 = 0
C4 = 0
C5 = 0
C6 = 0
C1 = 0
C2 = 0
C3 = 0
C4 = 0
C5 = 0
C6 = 0
C1 = 0
C2 = 0
C3 = 0
C4 = 0
C5 = 0
C6 = 0
C1 = 0
C2 = 0
C3 = 0
C4 = 0
C5 = 0
C6 = 0
C1 = 0
C2 = 0
C3 = 0
C4 = 0
C5 = 0
C6 = 0
Then I tried Leo's code:
0
0
0
0
0
0
C1 = 0
C2 = 0
C3 = 0
C4 = 0
C5 = 0
C6 = 0
C1 = 0
C2 = 0
C3 = 0
C4 = 0
C5 = 0
C6 = 0
C1 = 0
C2 = 0
C3 = 0
C4 = 0
C5 = 0
C6 = 0
C1 = 0
C2 = 0
C3 = 0
C4 = 0
C5 = 0
C6 = 0
C1 = 0
C2 = 0
C3 = 0
C4 = 0
C5 = 0
C6 = 0
The same results...
But then i've changed the #define ADDRESS 0x77 //0x76 to 0x76
Then I get these results... the temperature works fine I think. I've put the sensor outside and the temperature drops , but when it reaches 20 degrees, it's not correct .
Actual TEMP= 21.01 Actual PRESSURE= 504.23
RAW Temp D2= 8309316 RAW Pressure D1= 6239926
C1 = 43760
C2 = 39947
C3 = 26993
C4 = 24969
C5 = 32337
C6 = 27552
Actual TEMP= 20.75 Actual PRESSURE= 504.26
RAW Temp D2= 8301170 RAW Pressure D1= 6241510
C1 = 43760
C2 = 39947
C3 = 26993
C4 = 24969
C5 = 32337
C6 = 27552
Actual TEMP= 20.54 Actual PRESSURE= 504.26
RAW Temp D2= 8294964 RAW Pressure D1= 6242566
C1 = 43760
C2 = 39947
C3 = 26993
C4 = 24969
C5 = 32337
C6 = 27552
Actual TEMP= 20.32 Actual PRESSURE= 504.26
RAW Temp D2= 8288212 RAW Pressure D1= 6243750
C1 = 43760
C2 = 39947
C3 = 26993
C4 = 24969
C5 = 32337
C6 = 27552
Actual TEMP= 20.11 Actual PRESSURE= 504.29
RAW Temp D2= 8281746 RAW Pressure D1= 6245034
C1 = 43760
C2 = 39947
C3 = 26993
C4 = 24969
C5 = 32337
C6 = 27552
Actual TEMP= 141086.15 Actual PRESSURE= 156428.96
RAW Temp D2= 8275998 RAW Pressure D1= 6245854
C1 = 43760
C2 = 39947
C3 = 26993
C4 = 24969
C5 = 32337
C6 = 27552
Actual TEMP= 141086.01 Actual PRESSURE= 156495.70
RAW Temp D2= 8271354 RAW Pressure D1= 6246866
C1 = 43760
C2 = 39947
C3 = 26993
C4 = 24969
C5 = 32337
C6 = 27552
Actual TEMP= 141085.90 Actual PRESSURE= 156532.20
RAW Temp D2= 8267988 RAW Pressure D1= 6247420
C1 = 43760
C2 = 39947
C3 = 26993
C4 = 24969
C5 = 32337
C6 = 27552
The problem is when it reaches below 20 degrees.
The pressure isn't correct either.
Any solutions?
Many Thanks!!!
FRR
