Bonjour,
j’ai fais un altimètre un arduino pro mini en suivent ce tuto :
Le problème est que je n’est pas trouvé la même sonde de pression que dans le tuto mais, j’ai un modèle similaire avec les même broches et je ne sais pas ce que je doit modifié dans le programme pour que ça fonctionne?
MPL3115A2 Barometric Pressure Sensor Library Example Code
By: Nathan Seidle
SparkFun Electronics
Date: September 24th, 2013
License: This code is public domain but you buy me a beer if you use this and we meet someday (Beerware license).
Uses the MPL3115A2 library to display the current altitude and temperature
Hardware Connections (Breakoutboard to Arduino):
-VCC = 3.3V
-SDA = A4 (use inline 10k resistor if your board is 5V)
-SCL = A5 (use inline 10k resistor if your board is 5V)
-INT pins can be left unconnected for this demo
During testing, GPS with 9 satellites reported 5393ft, sensor reported 5360ft (delta of 33ft). Very close!
During testing, GPS with 8 satellites reported 1031ft, sensor reported 1021ft (delta of 10ft).
#include <Wire.h>
#include "MPL3115A2.h"
#include "SevSeg.h"
#include <Bounce2.h>
//#define SERIAL_DEBUG //Used for activating Serial Debugging
#define TITLE_MODE 1
#define VALUE_MODE 0
#define ALT 0
#define TOP 1
#define BOT 2
#define DIFF 3
#define STBY 4
//Create an instance of the object
MPL3115A2 myPressure;
SevSeg myDisplay;
unsigned long timer;
unsigned long titletimer;
const int buttonPin = 3; // the number of the pushbutton pin
int buttonState = 0; // variable for reading the pushbutton status
Bounce debouncer = Bounce();
char tempString[10]; //Used for sprintf
float maxaltitude = -99999;
float minaltitude = 99999;
boolean lastbutton = HIGH;
boolean currentbutton = HIGH;
int mode;
boolean metamode = TITLE_MODE;
char *s;
const int titletimerBeat = 1000; //fiddle away!
const int timerBeat = 500; //shouldn't be changed much
pinMode(buttonPin, INPUT_PULLUP);
debouncer.attach(buttonPin);
debouncer.interval(5);
Wire.begin(); // Join i2c bus
Serial.begin(9600); // Start serial for output
myPressure.begin(); // Get sensor online
int displayType = COMMON_CATHODE; //Your display is either common cathode or common anode
//This pinout is for a bubble dispaly
//Declare what pins are connected to the GND pins (cathodes)
int digit1 = A1; //Pin 1
int digit2 = 6; //Pin 10
int digit3 = 12; //Pin 4
int digit4 = 10; //Pin 6
//Declare what pins are connected to the segments (anodes)
int segA = 4; //Pin 12
int segB = 5; //Pin 11
int segC = 13; //Pin 3
int segD = 8; //Pin 8
int segE = A0; //Pin 2
int segF = 7; //Pin 9
int segG = 9; //Pin 7
int segDP= 11; //Pin 5
int numberOfDigits = 4; //Do you have a 1, 2 or 4 digit display?
myDisplay.Begin(displayType, numberOfDigits, digit1, digit2, digit3, digit4, segA, segB, segC, segD, segE, segF, segG, segDP);
myDisplay.SetBrightness(100); //Set the display to 100% brightness level
timer = millis();
titletimer = timer+titletimerBeat;
//Configure the sensor
myPressure.setModeAltimeter(); // Measure altitude above sea level in meters
//myPressure.setModeBarometer(); // Measure pressure in Pascals from 20 to 110 kPa
myPressure.setOversampleRate(7); // Set Oversample to the recommended 128
myPressure.enableEventFlags(); // Enable all three pressure and temp event flags
float altitude;
float pressure;
debouncer.update();
int buttonState = debouncer.read();
// buttonState = digitalRead(buttonPin);
lastbutton = currentbutton;
currentbutton = buttonState;
if (lastbutton == HIGH && currentbutton == LOW) {
if (mode >= STBY) mode = 0;
mode++;
titletimer = millis()+titletimerBeat;
if (millis() > titletimer) {
metamode = VALUE_MODE;
if (millis() > timer) {
timer = millis()+timerBeat;
//things to do every 500 milliseconds
altitude = myPressure.readAltitudeFt();
#ifdef SERIAL_DEBUG
Serial.print(" Altitude(ft):");
Serial.print(altitude, 2);
if (buttonState == HIGH) Serial.print("BUTTON PRESSED!");
#endif
if (altitude > maxaltitude) {
maxaltitude = altitude;
if (altitude < minaltitude) {
minaltitude = altitude;
if (metamode == VALUE_MODE) {
switch (mode) {
case ALT:
sprintf(tempString, "%4d", (int)altitude); //Convert altitude into a string that is right adjusted
case TOP:
sprintf(tempString, "%4d", (int)maxaltitude);
case BOT:
sprintf(tempString, "%4d", (int)minaltitude);
case DIFF:
sprintf(tempString, "%4d", (int)(maxaltitude - minaltitude));
case STBY:
sprintf(tempString, " ");
s = tempString;
else if (metamode == TITLE_MODE) {
switch (mode) {
case ALT:
s = "Alt ";
case TOP:
s = "HiGH";
case BOT:
s = "Lo ";
case DIFF:
s = "diFF";
case STBY:
s = "Stby";
#ifdef SERIAL_DEBUG
Serial.print(" OUR STR:");
Serial.print(s);
#endif
if(mode != STBY || metamode == TITLE_MODE) myDisplay.DisplayString(s, 0); //MUST STAY OUTSIDE OF "TIMER" IF STATEMENT!!!
