ruklis
September 26, 2018, 10:32am
1
need to write this array of bytes {0, 4, 110, 112, 255} once, then do nothing.
Will not write.
#include "Arduino.h"
// Be sure that the AltSoftSerial library is available, download it from http://www.pjrc.com/teensy/td_libs_AltSoftSerial.html"
#include "AltSoftSerial.h"
AltSoftSerial altSerial(8,9);
Serial.begin(19200);
altSerial.begin(10400);
byte data[5] = {0, 4, 110, 112, 255};
altSerial.write(data, 5);
delay(100);
system
September 26, 2018, 10:46am
2
If ALL you need to do is write that array ONE time, and then do NOTHING, why do you need to use a software serial port to do it? Why AltSoftSerial?
The AltSoftSerial constructor takes no arguments, so that code won't even compile.
ruklis
September 26, 2018, 11:04am
3
i need these bits to be sent at 10400 kbps to another device. Thats why i use softserial.
The code compiles in arduino ide, but no result in output.
system
September 26, 2018, 11:28am
4
So, the mysterious device that you have duct-taped to the Arduino doesn't respond to the data in the way you expect.
Perhaps its time to tell us what this mysterious device is, how it is connected to the Arduino, and what the device actually does, or what you expect it to do and WHY you expect it to do that.
ruklis
September 26, 2018, 11:36am
5
iso9141 device connected via buffer IC to arduino pins 8,9.
This byte array initiates system test.
Can you help me understand what 10400 kbps means? Presumably you meant 10,400 baud or 10.4kbps. In any event, just tested AltSoftSerial at 10,400 baud, didn't like it.
system
September 26, 2018, 12:04pm
7
So, grounds are not connected?
ruklis
September 26, 2018, 12:28pm
8
grounds connected, 5v and 12v connected.
system
September 26, 2018, 2:07pm
9
ruklis:
Instead of hand-waving about the connections, post a schematic, with links to the IC and the device connected to it.
