Alvik Will Not Charge
New Alvik has been nothing but disappointment. It seems to be functioning perfectly when plugged in, but will not charge. If instructions are to be believed, the RGB LED on the Nano is supposed to be green or red when plugged in to indicate charge. It is dark. By hand typing in the commands I can get it to tell me it has 0 charge. At least I guess that's what it is saying. Again, everything seems to be working perfectly. It is uploading and saving programs and they run fine - as long as it is plugged in. Any ideas?
Measure the charging voltage. Measure the battery's charge with a meter.
1.2V. Definitely not charging. The light does not show up red or green. No clue what else to try.
The "battery" is not charging, but the Alvik might be trying to charge the battery.
Try to measure the pins of the charging connector on the Alvik as the battery is "being charged."
A bad battery could happen.
