Always include certain code with every compile and upload
Problem: I'm using ArduinoOTA to OTA to my remote devices but if I forget to inlcude the arduinoOTA code in new uploads, my devices of course will not be reachable anymore OTA.
ASK: to avoid such events, is there a way to predefine Code which the Arduino IDE2.x automatically inserts during compile (e.g. the required OTA code) or at least brings up a warning if its not present?
May be you can Modify the main file that gets generated to include the code you want
It looks like this on esp32
Or this:
See for context
Thanks you @J-M-L and @dougp this was helpful, in particular for starting new projects. I will use this.
In the case I want to try some code I find (e.g. on github or here in the forum), I need something to insert the required OTA code at the right place.
I typed some python code which of course I need to execute on the .ino I want to upload first but it seems to work. I'm sure there are more elegant ways to solve this but in case anybody is interesed, here is my python code. The name of the .ino file which gets modified need to be specified as a cmd line parameter. Lets say you want to add OTA to blink.ino you would write:
python addcode.py blink.ino
as a command line.
Here is my python code for addcode.py:
import fileinput
import sys
filename = sys.argv[1]
OTA  = False
WiFi = False
for line in fileinput.input(filename, inplace=1):
 print(line, end='') # line in the file already have a \n so need to say ''
 if line.startswith('#include <ArduinoOTA.h>'):
  OTA = True
 if line.startswith('#include <WiFi.h>'):
  WiFi = True
if not OTA:
  if fileinput.isfirstline():
   print("#include <ArduinoOTA.h>", end='\n') # replave the first line with this string
   print(line, end='') # but then reprint the original line into the next line
  else:
   print(line, end='')  # if not first line just reprint the lines
  if line.startswith('void setup()'):
   print(line, end='')
   print("  WiFi.begin(ssid, password);", end='\n') # as there is no \n, it needs to be added
   print('  if (WiFi.waitForConnectResult() != WL_CONNECTED) {', end='\n')
   print('     Serial.println("WiFi Failed");', end='\n')
   print('     while(1) {', end='\n')
   print('       delay(1000);', end='\n')
   print('     }', end='\n')
   print('  ArduinoOTA.setHostname("tmpOTAname");', end='\n')  # here you can set the Hostname as it will be dislayed by OTA in the network
   print('  ArduinoOTA.setPassword("1234");', end='\n')
   print('  ArduinoOTA.begin();', end='\n')
  else:
   print(line, end='')
  if line.startswith('void loop()'):
   print(line, end='')
   print(' ArduinoOTA.handle();', end='\n')
  else:
   print(line, end='')
if not WiFi:
   print("#include <WiFi.h>")
   print('//=================================== WLAN credentials =============================================//')
   print('// Enter WLAN credentials here.        //')
   print('//==================================================================================================//')
   print('const char * ssid                     = "****";') # include your WiFi ssid here
   print('const char * password                 = "****";')   # include your WiFi password here
   print(line, end='')
  else:
   print(line, end= '')
