Hello hi everyone, Sorry i need some help to isolate my problem, everything in the code work well but only one part not working properly, i need when the condition is true in any if statement in a loop function to be executed per time and not continuously repeating again and again until when the condition become true again then the code inside that if statement should be executed again. now what it happen when the condition is true it execute fine only once the code inside that if statement but when the condition become true again the code inside that statement won't be executed again i don't know why it happen like that. i put comment on the part of the code that am facing the problem, please help me to solve my issue
#include <SoftwareSerial.h>
#include <Wire.h>
#include "MapFloat.h"
#include <DS3231.h>
#include <TinyGPS++.h>
#include <JQ6500_Serial.h>
#include <ArduinoJson.h>
DS3231 rtc(SDA, SCL);
JQ6500_Serial mp3(Serial2);
TinyGPSPlus gps;
LiquidCrystal_I2C lcd(0x27, 20, 4); // set the LCD address to 0x27
int sensorPin = 0; // select the analog input pin for the potentiometer
int sensorValue = 0; // variable to store the value coming from the sensor
const int relayPin = 2;
const int relayOnButton = 29;
const int relayOffButton = 28;
const int manualModeButton = 30;
const int autoModeButton = 31;
StaticJsonBuffer<200> jsonBuffer;
char deviceID[12] = "Mivumoni";
int relayState = LOW;
int mode = 0;
unsigned long lastRelayPressTime = 0;
unsigned long debounceDelay = 200;
unsigned long start;
double lat_val, lng_val, alt_m_val;
//float lat_val = -6.098756;
//float lng_val = 39.653409;
uint8_t hr_val, min_val, sec_val;
bool loc_valid, alt_valid, time_valid;
int waterLevel;
float percentage; // variable for height of liquid
float volume; // variable for volume in cu. in.
float water_height;
float distance;
float tank_height = 3.50;
unsigned long startTime_gprs = 0;
unsigned long interval_gprs = 300000;
unsigned long startTime_Voice = 0;
unsigned long interval_Voice = 1000;
unsigned long startTime_rtc = 0;
unsigned long interval_rtc = 1000;
unsigned long startTime_delay = 0;
unsigned long interval_delay = 1000;
unsigned long startTime_gps = 0;
unsigned long interval_gps = 800;
static unsigned long DelayRequired = 0;
static int CurrentStep = 0;
static unsigned long PrevMillis = 0;
unsigned long currentTime = millis();
String sendtoserver;
int flag1 = 0;
int flag2 = 0;
int flag3 = 0;
int flag4 = 0;
int flag5 = 0;
int flag6 = 0;
Serial2.begin(9600);
rtc.begin();
lcd.init(); // initialize the lcd
lcd.init();
// Print a message to the LCD.
lcd.backlight();
mp3.reset();
mp3.setVolume(40);
mp3.setLoopMode(MP3_LOOP_NONE);
mp3.setEqualizer(MP3_EQ_ROCK);
mp3.playFileByIndexNumber(7);
pinMode(relayPin, OUTPUT);
pinMode(relayOnButton, INPUT);
pinMode(relayOffButton, INPUT);
pinMode(manualModeButton, INPUT);
pinMode(autoModeButton, INPUT);
DynamicJsonBuffer jsonBuffer;
delay(4000);
lcd.clear();
//if (currentTime - startTime_gps >= interval_gps)
startTime_gps = currentTime;
smartDelay(200); /* Generate precise delay of 1ms */
lat_val = gps.location.lat(); /* Get latitude data */
loc_valid = gps.location.isValid(); /* Check if valid location data is available */
lng_val = gps.location.lng(); /* Get longtitude data */
time_valid = gps.time.isValid(); /* Check if valid time data is available */
int relayOnButtonState = digitalRead(relayOnButton);
int relayOffButtonState = digitalRead(relayOffButton);
int manualModeButtonState = digitalRead(manualModeButton);
int autoModeButtonState = digitalRead(autoModeButton);
if ( manualModeButtonState == HIGH) {
mode = 1;
} if ( autoModeButtonState == HIGH) {
mode = 0;
if (mode == 1) {
sensorValue = analogRead(sensorPin);
distance = mapFloat(sensorValue, 540, 261, 5.0, 0.45);
volume = mapFloat(percentage, 0, 100, 0, 5000000);
water_height = (tank_height - distance) + 1.110;
percentage = mapFloat(water_height, 0.45, 3.50, 0, 100);
lcd.clear();
lcd.setCursor(10, 2);
lcd.print("MANUAL");
if (volume < 0.00)
volume = 0.00;
if (volume > 5000000.00)
volume = 5000000.00;
if (percentage < 0.00)
percentage = 0.00;
if (percentage > 100.00)
percentage = 100.00;
if (water_height < 0.30)
water_height = 0.00;
if (water_height > 3.5)
water_height = 3.5;
if (currentTime - startTime_rtc >= interval_rtc)
startTime_rtc = currentTime;
lcd.setCursor(0, 0);
lcd.print(rtc.getDateStr());
lcd.print(" ");
lcd.print(rtc.getTimeStr());
lcd.setCursor(0, 1);
lcd.print(volume, 2);
lcd.setCursor(11, 1);
lcd.print("|");
lcd.setCursor(13, 1);
lcd.print(percentage, 2);
lcd.print("%");
lcd.setCursor(0, 2);
lcd.print(water_height, 2);
lcd.print("M");
lcd.setCursor(7, 2);
lcd.print("|");
lcd.setCursor(0, 3);
lcd.print(lat_val, 4);
lcd.print(" ");
lcd.print(lng_val, 4);
if (relayOnButtonState == HIGH && millis() - lastRelayPressTime >= debounceDelay) {
relayState = HIGH;
digitalWrite(relayPin, relayState);
lastRelayPressTime = millis();
if (relayOffButtonState == HIGH && millis() - lastRelayPressTime >= debounceDelay) {
relayState = LOW;
if (relayState == HIGH)
lcd.setCursor(17, 3);
lcd.print("ON");
else if (relayState == LOW)
lcd.print("OFF");
} else if (mode == 0) {
lcd.clear();
lcd.print("AUTOMATIC");
if (volume < 0.00)
volume = 0.00;
percentage = 0.00;
water_height = 3.5;
lcd.print(" ");
lcd.print("|");
lcd.print("%");
lcd.print("M");
lcd.print("|");
lcd.print(" ");
if (water_height >= 3.50) {
relayState = LOW;
lcd.print("OFF");
else if (waterLevel <= 1.00) {
relayState = HIGH;
lcd.print("ON");
// starting part that I'm facing the problem
if (mode == 1 && flag1 == 0) {
mp3.setVolume(40);
mp3.playFileByIndexNumber(2);
flag1 = 1; // Set Flag 1 to true
if (mode == 1 && relayState == HIGH && flag2 == 0)
mp3.setVolume(40);
mp3.playFileByIndexNumber(6);
flag2 = 1; // Set Flag 1 to true
if (mode == 1 && relayState == LOW && flag3 == 0)
mp3.setVolume(40);
mp3.playFileByIndexNumber(4);
flag3 = 1; // Set Flag 1 to true
if (mode == 0 && flag4 == 0) {
mp3.setVolume(40);
mp3.playFileByIndexNumber(1);
flag4 = 1; // Set Flag 1 to true
if (mode == 0 && relayState == LOW && flag5 == 0 ) {
mp3.setVolume(40);
mp3.playFileByIndexNumber(8);
mp3.playFileByIndexNumber(3);
flag5 = 1; // Set Flag 1 to true
if (mode == 0 && relayState == HIGH && flag6 == 0) {
mp3.setVolume(40);
mp3.playFileByIndexNumber(9);
mp3.playFileByIndexNumber(5);
flag6 = 1; // Set Flag 1 to true
// ending part that I'm facing the problem
static void smartDelay(unsigned long ms)
unsigned long start = millis();
do
while (Serial1.available()) /* Encode data read from GPS while data is available on serial port */
gps.encode(Serial1.read());
/* Encode basically is used to parse the string received by the GPS and to store it in a buffer so that information can be extracted from it */
} while (millis() - start < ms);
