Am I over expecting Arduino Scripts
HI,
Just starting to bury myself in Arduino after sitting on the sidelines to long
I have been trying to modify the Fade-in/Fade-out LED Script in “getting started with Arduino”, What I would like to do is to make 6 LEDs fade in and out, one after the other and then once working make it a “random” order
Ia m reasonably competent with C, so I have modifed the script as below:
const int LED = {3,5,6,9,10,11};
int i,j = 0;
for (j=1; j>6; j++)
pinMode(LED[j], OUTPUT);
for (j=1; j>6; j++)
for (i=0;i<255;i++)
analogWrite(LED[j],i);
delay(10);
for (j=1; j>6; j++)
for (i=255;i>0;i–)
delay(10);
I am getting the feeling that I cannot pass the PMW output as a variable, so will have to do it using a nested If…Then.Else or CASE statement
Would anyone in the hive-mind please put me right ?
Thank you
(deleted)
const int LED[] = {3,5,6,9,10,11};
Array index begin at 0 so this array runs from LED[0] to LED[5]
  for (j=1; j>6; j++)
This syntax is wrong, and should be
for (j=0; j<6; j++)
The same incorrect array handling also appears twice in loop().
const byte LED[6] = {3, 5, 6, 9, 10, 11};
  for (byte j = 0; j < 6; j++)
    for (byte i = 0; i < 255; i++)
      analogWrite(LED[j], i);
      unsigned long _time = millis();
      const byte _delay = 10;
      while (_time - millis() < _delay) {}
    for (byte i = 255; i > 0; i--)
even though I`m not counting myself as competent in C programming language.
Sketch uses 1148 bytes (3%) of program storage space. Maximum is 32256 bytes.
Global variables use 15 bytes (0%) of dynamic memory, leaving 2033 bytes for local variables. Maximum is 2048 bytes.
