Amarino 'problem'
I’m trying to use Amarino’s compass to blink LED.
I used Amarino’s example
  Receives compass sensor events from your phone.
 #include <SoftwareSerial.h>
#include <MeetAndroid.h>
// MeetAndroid meetAndroid();
// you can define your own error function to catch messages
// where not fuction has been attached for
MeetAndroid meetAndroid(error);
void error(uint8_t flag, uint8_t values){
  Serial.print("ERROR: ");
  Serial.print(flag);
int onboardLed = 13;
  // use the baud rate your bluetooth module is configured to
  // not all baud rates are working well, i.e. ATMEGA168 works best with 57600
  Serial1.begin(9600);
  // register callback functions, which will be called when an associated event occurs.
  // - the first parameter is the name of your function (see below)
  // - match the second parameter ('A', 'B', 'a', etc...) with the flag on your Android application
  meetAndroid.registerFunction(compass, 'A');
  pinMode(onboardLed, OUTPUT);
  digitalWrite(onboardLed, HIGH);
  meetAndroid.receive(); // you need to keep this in your loop() to receive events
 * This method is called constantly.
 * Compass events are sent several times a second.
 * note: flag is in this case 'A' and numOfValues is 1
 * since compass event sends exactly one single int value for heading
void compass(byte flag, byte numOfValues)
  // we use getInt(), since we know only data between 0 and 360 will be sent
  int heading = meetAndroid.getInt();
  flushLed(heading); // silly, you should have better ideas
void flushLed(int time)
  digitalWrite(onboardLed, LOW);
  delay(time);
but nothing happens.
Also tried their ‘Test’ code, changed baud rates, but nothing happened…
Don’t know where can be problem, because phone successfully connects to Aruino but looks like it can’t send any data…
I’m using HC-05 module, and everything works perfect with other codes and apps that I’ve made with App Inventor. Phone is HTC Wildfire (Android 2.3.3).
Does anybody know where can be problem?
