Amazon Pixnor UNO It Work JUST Touch Or LCD
Hy, i buy from amazon THAT 2.8 TFT display
Buy i have a problem:
i'm using that code whit adafruit librarys:
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_TFTLCD.h> // Hardware-specific library
#include <TouchScreen.h>
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_RESET A4
#define SD_CS 10
int x1,x2,c1,result,sw=0;
#define YP A2  // must be an analog pin, use "An" notation!
#define XM A1  // must be an analog pin, use "An" notation!
#define YM 6   // can be a digital pin
#define XP 7   // can be a digital pin
#define TS_MINX 173
#define TS_MINY 146
#define TS_MAXX 831
#define TS_MAXY 889
// For better pressure precision, we need to know the resistance
// between X+ and X- Use any multimeter to read it
// For the one we're using, its 300 ohms across the X plate
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 330);
// Assign human-readable names to some common 16-bit color values:
#define BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define PURPLE   0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
#define ORANGE     0xFBE0
#define LGRAY     0xBDF7
#define DGRAY     0x7BEF
#define BROWN     0x79E0
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);;
#define BOXSIZE 50
#define PENRADIUS 3
int oldcolor, currentcolor;
int ics;
void setup(void) {
  tft.reset();
  uint16_t identifier = tft.readID();
    identifier=0x9341;
  tft.begin(identifier);
 tft.fillScreen(BLACK);
    tft.setRotation(3); // landscape 320*240 , mode 2 = 240*320
  tft.setCursor(30, 140);
  tft.setTextColor(WHITE);
  tft.setTextSize(3);
  tft.println("LOADING...");
  tft.fillRect(10, 20, BOXSIZE, BOXSIZE, ORANGE);
  tft.fillRect(10, 75, BOXSIZE, BOXSIZE, ORANGE);
  tft.fillRect(10, 130, BOXSIZE, BOXSIZE, ORANGE);
  tft.fillRect(65, 20, BOXSIZE, BOXSIZE, ORANGE);
  tft.fillRect(65,75, BOXSIZE, BOXSIZE, ORANGE);
  tft.fillRect(65, 130, BOXSIZE, BOXSIZE, ORANGE);
  tft.fillRect(65, 185, BOXSIZE, BOXSIZE,  ORANGE);
  tft.fillRect(120, 20, BOXSIZE, BOXSIZE, ORANGE);
  tft.fillRect(120,75, BOXSIZE, BOXSIZE, ORANGE);
  tft.fillRect(120, 130, BOXSIZE, BOXSIZE, ORANGE);
  tft.fillRect(120, 185, BOXSIZE, BOXSIZE,  LGRAY);
  tft.fillRect(175, 20, BOXSIZE, BOXSIZE, BROWN);
  tft.fillRect(175,75, BOXSIZE, BOXSIZE, PURPLE);
  tft.fillRect(175, 130, BOXSIZE, BOXSIZE, RED);
  tft.fillRect(175, 185, BOXSIZE, BOXSIZE,  BLUE);
   tft.fillRect(0, 255, 240, 50,  WHITE);
  num();
pinMode(13,OUTPUT);
#define MINPRESSURE 100
#define MAXPRESSURE 1000
  digitalWrite(13, HIGH);
  // Recently Point was renamed TSPoint in the TouchScreen library
  // If you are using an older version of the library, use the
  // commented definition instead.
  // Point p = ts.getPoint();
  TSPoint p = ts.getPoint();
 digitalWrite(13,LOW);
  // if sharing pins, you'll need to fix the directions of the touchscreen pins
 pinMode(XP, OUTPUT);
  pinMode(XM, OUTPUT);
  pinMode(YP, OUTPUT);
  pinMode(YM, OUTPUT);
 Serial.println(p.x);
 Serial.println(p.y);
 delay(400);
 if (p.z > MINPRESSURE && p.z < MAXPRESSURE) {
p.x = map(p.x, TS_MINX, TS_MAXX, 240, 0);
p.y = map(p.y, TS_MINY, TS_MAXY, 320, 0);
    if ( p.x > 10 && p.x < 70 && p.y > 15 && p.y < 70 )
 if(sw==0) {
   x1=1;
 else if(sw==1) {x2=1;}
   else  if ( p.x > 70 && p.x < 130 && p.y > 15 && p.y < 70 )
  if(sw==0) {
   x1=2;
 else if(sw==1) {x2=2;}
     else  if ( p.x > 130 && p.x < 190 && p.y > 15 && p.y < 70 )
  if(sw==0) {
   x1=3;
 else if(sw==1) {x2=3;}
     else  if ( p.x > 190 && p.x < 240 && p.y > 15 && p.y < 70 )
        sw=1;
 c1=4;
     else  if ( p.x > 10 && p.x < 70 && p.y > 70 && p.y < 130 )
  if(sw==0) {
   x1=4;
 else if(sw==1) {x2=4;}
     else  if ( p.x > 70 && p.x < 130 && p.y > 70 && p.y < 130 )
  if(sw==0) {
   x1=5;
 else if(sw==1) {x2=5;}
     else  if ( p.x > 130 && p.x < 190 && p.y > 70 && p.y < 130 )
  if(sw==0) {
   x1=6;
 else if(sw==1) {x2=6;}
     else  if ( p.x > 190 && p.x < 240 && p.y > 70 && p.y < 130 )
        sw=1;
 c1=3;
      else  if ( p.x > 10 && p.x < 70 && p.y > 130 && p.y < 190 )
        if(sw==0) {
   x1=7;
 else if(sw==1) {x2=7;}
     else  if ( p.x > 70 && p.x < 130&& p.y > 130 && p.y < 190 )
        if(sw==0) {
   x1=8;
 else if(sw==1) {x2=8;}
     else  if ( p.x > 130 && p.x < 190 && p.y > 130 && p.y < 190 )
       if(sw==0) {
   x1=9;
 else if(sw==1) {x2=9;}
     else  if ( p.x > 190 && p.x < 240 && p.y > 130 && p.y < 190 )
 sw=1;
 c1=1;
       else  if ( p.x > 0 && p.x < 240 && p.y > 270 && p.y < 320 )
       sw=0;
       c1=0;
     else  if ( p.x > 70 && p.x < 130 && p.y > 190 && p.y < 240 )
       if(sw==0) {
   x1=0;
 else if(sw==1) {x2=0;}
     else  if ( p.x > 130 && p.x < 190 && p.y > 190 && p.y < 240 )
  sw=0;
 if(c1==1) {result=x1-x2;}
else if(c1==2) {result=x1+x2;}
else if(c1==3) {result=x1*x2;}
else if(c1==4) {result=x1/x2;}
 tft.setTextColor(BLACK);
 tft.setTextSize(4);
  tft.setCursor(90, 260);
 tft.println(result);
     else  if ( p.x > 190 && p.x < 240 && p.y > 190 && p.y < 240 )
        sw=1;
 c1=2;
void num() {
 tft.drawLine(0,240,240,240,WHITE);
 tft.drawLine(0,15,240,15,WHITE);
 tft.drawLine(172,15,172,182,WHITE);
 tft.drawLine(117,182,172,182,WHITE);
  tft.drawLine(117,182,117,240,WHITE);
 tft.setTextSize(4);
  tft.setCursor(25, 30);
 tft.println("1");
  tft.setCursor(80, 30);
 tft.println("2");
 tft.setCursor(135, 30);
 tft.println("3");
 tft.setCursor(190, 30);
 tft.println("/");
   tft.setCursor(25, 85);
 tft.println("4");
  tft.setCursor(80, 85);
 tft.println("5");
 tft.setCursor(135, 85);
 tft.println("6");
 tft.setCursor(190, 85);
 tft.println("x");
   tft.setCursor(25, 140);
 tft.println("7");
  tft.setCursor(80, 140);
 tft.println("8");
 tft.setCursor(135, 140);
 tft.println("9");
 tft.setCursor(190, 140);
 tft.println("-");
  tft.setCursor(80, 195);
 tft.println("0");
 tft.setCursor(135, 195);
 tft.println("=");
 tft.setCursor(190, 195);
 tft.println("+");
But if i use only touch screen or only LCD the single things work fine, but when i try to use touch and LCD i can't read position.
I try to change bits inside the touch class but dont work...
I'have attached the model pic and his pins
You have a regular "Blue 2.8 inch Mcufriend shield".
These come with different controllers. ILI9341 is commonly used.
These come with different wiring of the Touch Panel. e.g. A1, 7, A2, 6 or A2, 9, A3, 8
David.
Solved:
It wordk whith:
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define SD_CS 10
#define XM A3  // must be an analog pin, use "An" notation!
#define YM 8   // can be a digital pin
#define XP 9   // can be a digital pin
