Ambient lighting issue (Please Help)
Hello All-
I would greatly appreciate some help. I apologize for the long post, just want to explain everything. I have a 30 channel ambient lighting setup with Arduino Uno Rev3 connected to two tlc5940 on a breadboard as per instructable http://www.instructables.com/id/30-channel-LED-RGB-Ambilight-Clone/
I am using 10 led strips connected to the tlc's.
I am using hardware setup based on Google Code Archive - Long-term storage for Google Code Project Hosting.
However, I keep getting error message when opening boblight "Wrong channel value 3 for device uCon on light left_upper"
I swapped led colors, strips, and even tried another breadboard. But same message. When I upload the amblight.pde to arduino, the led strips do react, however, can't get it to work. Also when I run boblight-getpixel, it always times out.
Can someone Please please guide me on how to get this working.... I am running Windows 7 64 bit pc
My boblight config file is as follow:
[global]
interface 127.0.0.1
[device]
name uCon
output "COM7
"channels 30
type momo
interval 20000
prefix FF
rate 115200
debug on
name red
rgb FF0000
name green
rgb 00FF00
name blue
rgb 0000FF
[light]
name left_upper
color red uCon 3
color green uCon 2
color blue uCon 1
hscan 0 20
vscan 0 50
[light]
name left_lower
color red uCon 6
color green uCon 5
color blue uCon 4
hscan 0 20
vscan 50 100
[light]
name bottom_left
color red uCon 7
color green uCon 8
color blue uCon 9
hscan 0 33
vscan 80 100
[light]
name bottom_middle
color red uCon 12
color green uCon 11
color blue uCon 10
hscan 33 67
vscan 80 100
etc. etc.
What is boblight?
Where is the error message given? What code are you trying to run?
It is not at all likely that you get an error message if you have the wiring wrong, it is normally purely software mistakes that give software errors.
