Amblone code compiling error [TCCR2B not declared]
Hey guys, new to these forums, and PRETTYY new to Arduino :slight_smile:
I’m trying to set up Amblone for my room, and im having some trouble with the Arduino code side of things. I’m running IDE 1.0.5
Basically, when I try to compile :
// Amblone code for the Arduino Mega
// Author: Bart van der Drift
// License:
// Anyone is free to change, redistribute or copy parts of this code
// as long as it is not for commercial purposes
// Please be so kind to pay credit where due
//---------------------------------- DEFINES --------------------------------
// Flags for the USB communication protocol
#define C_SF1 0xF1 // Startflag for 1-channel mode (1 RGB channel)
#define C_SF2 0xF2 // Startflag for 2-channel mode (2 RGB channels)
#define C_SF3 0xF3 // Startflag for 3-channel mode (3 RGB channels)
#define C_SF4 0xF4 // Startflag for 4-channel mode (4 RGB channels)
#define C_END 0x33 // End flag
#define C_ESC 0x99 // Escape character
// States for receiving the information, see the flow chart for more info
#define S_WAIT_FOR_SF  0
#define S_RECV_RGB     1
#define S_RECV_RGB_ESC 2
//--------------------------- FUNCTION DECLARATIONS -------------------------
// Receives bytes and returns true if a valid packet was received
boolean PacketReceived();
// Uses the rgb values to set the PWMs
void SetPWMs();
//--------------------------- VARIABLE DECLARATIONS -------------------------
int pulse = 0;
// State we are in: one of the S_* defines
int State = 0;
// The payload of a received message
int Payload[32];
// The amount of RGB values we have received
int ByteCount = 0;
// The character we received
int Recv;
// The amount of RGB channels we are using
int ChannelMode;
// PWM pins for channel 1
int r1_pin = 2;
int g1_pin = 3;
int b1_pin = 4;
// PWM pins for channel 2
int r2_pin = 5;
int g2_pin = 6;
int b2_pin = 7;
// PWM pins for channel 3
int r3_pin = 8;
int g3_pin = 9;
int b3_pin = 10;
// PWM pins for channel 4
int r4_pin = 11;
int g4_pin = 12;
int b4_pin = 13;
//----------------------------- IMPLEMENTATIONS -----------------------------
void setup()   {
  // initialize the serial communication
  Serial.begin(256000);	// opens serial port, sets data rate to 256000 bps
  TCCR0B = TCCR0B & 0b11111000 | 0x2;
  TCCR1B = TCCR0B & 0b11111000 | 0x2;
  TCCR2B = TCCR0B & 0b11111000 | 0x2;
  TCCR3B = TCCR0B & 0b11111000 | 0x2;
  TCCR4B = TCCR0B & 0b11111000 | 0x2;
  State = S_WAIT_FOR_SF;
  if (Serial.available() > 0) {
    if (PacketReceived()) {
      SetPWMs();
boolean PacketReceived() {
  Recv = Serial.read();
  switch (State) {
    case S_WAIT_FOR_SF:
      // =============================== Wait for start flag state
      switch (Recv) {
        case C_SF1:
          // Start flag for 1-channel mode
          ChannelMode = 1;
          State = S_RECV_RGB;
          ByteCount = 0;
          return false;
        case C_SF2:
          // Start flag for 2-channel mode
          ChannelMode = 2;
          State = S_RECV_RGB;
          ByteCount = 0;
          return false;
        case 243://C_SF3:
          // Start flag for 3-channel mode
          ChannelMode = 3;
          State = S_RECV_RGB;
          ByteCount = 0;
          return false;
        case C_SF4:
          // Start flag for 4-channel mode
          ChannelMode = 4;
          State = S_RECV_RGB;
          ByteCount = 0;
          return false;
        default:
          // No action for all other characters
          return false;
    case S_RECV_RGB:
      // =============================== RGB Data reception state
      switch (Recv) {
        case C_SF1:
          ChannelMode = 1;
          State = S_RECV_RGB;
          ByteCount = 0;
          return false;
        case C_SF2:
          ChannelMode = 2;
          State = S_RECV_RGB;
          ByteCount = 0;
          return false;
        case C_SF3:
          ChannelMode = 3;
          State = S_RECV_RGB;
          ByteCount = 0;
          return false;
        case C_SF4:
          ChannelMode = 4;
          State = S_RECV_RGB;
          ByteCount = 0;
          return false;
        case C_END:
          // End Flag
          // For each channel, we should have received 3 values. If so, we have received a valid packet
          if (ByteCount == ChannelMode * 3) {
            ByteCount = 0;
            return true; // <------------------------ TRUE IS RETURNED
          else {
            // Something's gone wrong: restart
            ByteCount = 0;
            return false;
        case C_ESC:
          // Escape character
          State = S_RECV_RGB_ESC;
          return false;
        default:
          // The character received wasn't a flag, so store it as an RGB value
          Payload[ByteCount] = Recv;
          ByteCount++;
          return false;
      case S_RECV_RGB_ESC:
        // =============================== RGB Escaped data reception state
        // Store the value in the payload, no matter what it is
        ByteCount++;
        State = S_RECV_RGB;
        return false;
  return false;
void SetPWMs() {
  // Channel 1
  analogWrite(r1_pin, Payload[0]);
  analogWrite(g1_pin, Payload[1]);
  analogWrite(b1_pin, Payload[2]);
  // Channel 2
  if (ChannelMode > 1) {
    analogWrite(r2_pin, Payload[3]);
    analogWrite(g2_pin, Payload[4]);
    analogWrite(b2_pin, Payload[5]);
  else {
    // turn the rest to 0 (black)
    analogWrite(r2_pin, 0);
    analogWrite(g2_pin, 0);
    analogWrite(b2_pin, 0);
    analogWrite(r3_pin, 0);
    analogWrite(g3_pin, 0);
    analogWrite(b3_pin, 0);
    analogWrite(r4_pin, 0);
    analogWrite(g4_pin, 0);
    analogWrite(b4_pin, 0);
  // Channel 3
  if (ChannelMode > 2) {
    analogWrite(r3_pin, Payload[6]);
    analogWrite(g3_pin, Payload[7]);
    analogWrite(b3_pin, Payload[8]);
  else {
  // Channel 4
  if (ChannelMode > 3) {
    analogWrite(r4_pin, Payload[9]);
    analogWrite(g4_pin, Payload[10]);
    analogWrite(b4_pin, Payload[11]);
  else {
I get the error:
amblone.pde: In function 'void setup()':
amblone:84: error: 'TCCR2B' was not declared in this scope
D:
If I comment this out, It compiles fine. But its PROBABLY important ^^"
I dont understand why its doing this, so I would appreciate any input as to why :slight_smile:
To my understanding, this error is because its not declared with an int correct ? Yet, none of the other ones do…
Would appreciate any help !! :smiley:
Edit: Also, I plan on running this on an Arduino UNO. Not Mega… Is this a problem ? Will I have to change the pins to match PWM pins on the UNO and all will run well ?
-Count
No probably about it. Which Arduino are you trying to compile that for? Which Arduino was it written for?
It compiled OK for me using IDE 1.0.5 and the Mega board selected.
