Hi all,
I've come to your forum in the hope of finding help for a small problem I'm having. A problem that seems simple but is starting to drive me crazy (I've been looking for a solution for over a week).
I'm trying to explain it to you in the simplest way possible.
I have two cards, one is Atmega328P BLE and the other is STM32F103C8T6.
My first card (Atmega328P BLE) gets information from a sensor. It sends it to me via Bluetooth to my phone and it works fine. The small problem is that I would like this card to send the same information to the second card (the STM32F103C8T6), and I am having trouble setting up the I2C system.
My second board (STM32F103C8T6) needs to get a variable (the result of my probe on the Atmega328P BLE board) to make calculations.
My goal is to get the value of the 'eContent' variable in this code (which works perfectly), here is the code for the atmega328p BLE:
#include <Wire.h>
#define A1 1
#define SENSOR_PIN 10
bool featurePWMout = 1, featureAnalogInA1 = 0;
int eContentSkew = 50, refreshDelay = 0, eContentOverride = 0, voltOUTRange = 0;
unsigned int counttick = 0;
if (featurePWMout) {
TCCR1B = TCCR1B & 0b11111000 | 0x01;
int analogOut = 255 * (0.1 / 5.0);
unsigned long highTime = pulseIn(SENSOR_PIN, HIGH);
unsigned long lowTime = pulseIn(SENSOR_PIN, LOW);
unsigned long pulsetime = highTime + lowTime;
float VInA1;
int AverageVoltagebitsA1;
int AltA1;
if (featureAnalogInA1) {
AverageVoltagebitsA1 = 0;
int MeasurementsToAverage = 16;
for (int i = 0; i < MeasurementsToAverage; ++i) {
AverageVoltagebitsA1 += MeasureVoltage();
delay(1);
AverageVoltagebitsA1 /= MeasurementsToAverage;
VInA1 = AverageVoltagebitsA1 * (5.0 / 1023.0);
VInA1 = 0.0;
if (pulsetime > 20100 || pulsetime < 6400) {
if (counttick >= 2) {
if (voltOUTRange) {
if (pulsetime == 0) {
if (pulsetime >= 20100) {
int analogOut = 255 * (4.8 / 5.0);
if ((pulsetime <= 6400) && (pulsetime >= 1)) {
int analogOut = 255 * (4.9 / 5.0);
Serial.print("[");
Serial.print("=");
Serial.print(pulsetime);
Serial.print(",");
Serial.print("-,");
Serial.print("-,");
Serial.print(",");
Serial.print(VInA1, 1);
Serial.print("]");
} else if (counttick < 2) {
counttick++;
return;
long eContent = int((1000000 / pulsetime) - eContentSkew);
if (eContentOverride) {
eContent = eContentOverride;
if (eContent < 0) {
eContent = 0;
} else if (eContent > 100) {
eContent = 100;
float frequency = float(1000000 / pulsetime);
float dutyCycle = 100 * (highTime / float(lowTime + highTime));
float totalTime = float(1.0 / frequency);
float period = float(100 - dutyCycle) * totalTime;
int temperature = 40.25 * 10 * period - 81.25;
int temperatureF = temperature * 1.8 + 32;
if (temperatureF < -39 || temperatureF > 250) {
return;
float desiredVoltage;
if (voltOUTRange) {
desiredVoltage = mapf(eContent, 0, 100, 0.5, 4.5);
desiredVoltage = mapf(eContent, 0, 100, 0, 5);
int analogOut = 255 * (desiredVoltage / 5.0);
Serial.print("[");
Serial.print(temperature);
Serial.print(",");
Serial.print(eContent);
Serial.print(",");
Serial.print(desiredVoltage, 1);
Serial.print(",");
Serial.print(",");
Serial.print("]");
delay(refreshDelay);
counttick = 0;
double mapf(double x, double in_min, double in_max, double out_min, double out_max) {
return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
int MeasureVoltage() {
int rawbitsA1 = analogRead(A1);
return rawbitsA1;
And to get the value of the variable 'econtent' in this code to use it (STM32F103C8T6 code)
boolean injection1 = false, injection2 = false, reception = false, ColdStart = false, FivemStart = false;
unsigned long time_cyl1 = 0UL, time_cyl2 = 0UL, time_E85_cyl1 = 0UL, time_E85_cyl2 = 0UL, watchdog1 = 0UL, watchdog2 = 0UL, RunTimeEngine = 0UL, AckRept = 0UL;
int P_ETH = 0; /// P_ETH is the result of econtent from atmega328P
int TempAmb;
int percent_prolongation = 0;
#include <Thermistor.h>
#include <NTC_Thermistor.h>
#define SENSOR_PIN PA0
#define REFERENCE_RESISTANCE 10458
#define NOMINAL_RESISTANCE 11470
#define NOMINAL_TEMPERATURE 22.3
#define B_VALUE 3950
#define STM32_ANALOG_RESOLUTION 4095
Thermistor* thermistor;
disableDebugPorts();
pinMode(PB12, INPUT);
pinMode(PB13, INPUT);
pinMode(PB14, OUTPUT);
pinMode(PB4, OUTPUT);
pinMode(PB8, OUTPUT);
pinMode(PB9, OUTPUT);
digitalWrite(PB14, HIGH);
digitalWrite(PB4, HIGH);
attachInterrupt(PB12, Injection_Cyl_1, CHANGE);
attachInterrupt(PB13, Injection_Cyl_2, CHANGE);
Serial.begin(19200);
thermistor = new NTC_Thermistor(
SENSOR_PIN,
REFERENCE_RESISTANCE,
NOMINAL_RESISTANCE,
NOMINAL_TEMPERATURE,
B_VALUE,
TempAmb = int(thermistor->readCelsius());
if (TempAmb < 10) {
ColdStart = true;
digitalWrite(PB4, LOW);
RunTimeEngine = millis();
//if (Serial.available()) {the code to put for the I2C communication and for the Econtend variable to give a value to P_ETH !?!!!?!!}
if (millis() < (AckRept + 5000UL)) {
digitalWrite(PB14, LOW);
} else digitalWrite(PB14, HIGH);
if ((millis() > (RunTimeEngine + 30000UL )) && (FivemStart == false)) {
Calculate_P_ETH();
FivemStart = true;
if (injection1 == true) {
injection1 = false;
while (time_E85_cyl1 > micros());
digitalWrite(PB9, LOW);
if (injection2 == true) {
injection2 = false;
while (time_E85_cyl2 > micros());
digitalWrite(PB8, LOW);
if (watchdog1 < micros()) {
injection1 = false;
if (watchdog2 < micros()) {
injection2 = false;
void Calculate_P_ETH() {
P_ETH = constrain(P_ETH, 10, 85);
if ((millis() < (RunTimeEngine + 30000UL )) && (ColdStart == true)) percent_prolongation = (((8 * P_ETH) / 10) - 8);
else percent_prolongation = (((34 * P_ETH) - 430) / 75);
void Injection_Cyl_1() {
noInterrupts();
if (digitalRead(PB12) == HIGH) {
time_cyl1 = micros() - time_cyl1; // injection Time elpased in microseconds
time_E85_cyl1 = (micros() + ((time_cyl1 * percent_prolongation) / 100));
injection1 = true; // Flag for the end of injection traitement.
else {
watchdog1 = micros() + 1000000UL;
time_cyl1 = micros();
injection1 = false;
digitalWrite(PB9, HIGH);
interrupts();
void Injection_Cyl_2() {
noInterrupts();
if (digitalRead(PB13) == HIGH) {
time_cyl2 = micros() - time_cyl2;
time_E85_cyl2 = (micros() + ((time_cyl2 * percent_prolongation) / 100));
injection2 = true;
else {
watchdog2 = micros() + 1000000UL;
time_cyl2 = micros();
injection2 = false;
digitalWrite(PB8, HIGH);
interrupts();
Thank you in advance for your valuable help,
Julie.
