Dear all,
I am trying out AMG8833 thermal cam with arduino mega and UTFT ILI9341 library. I tried to use the original code with minimal modifications for UTFT. The result was a slow, misshapen thing whose grid produces nothing like an image of an object. Can anyone tell me if there is limitation for this arduino card and or the libraries. Attached is the adapted code.
Thanks for any help
Cesar
#include <UTFT.h>
#include <URTouch.h>
UTFT tft(ILI9341_16,38,39,40,41); //Parameters should be adjusted to your Display/Schield model
URTouch myTouch( 6, 5, 4, 3, 2);
extern uint8_t SmallFont[];
#define YAXIS 0 //Axis of the TFT sceen
#define XAXIS 1
#include <Adafruit_AMG88xx.h>
#define SHOW_TEMP_TEXT
//low range of the sensor (this will be blue on the screen)
#define MINTEMP 20
//high range of the sensor (this will be red on the screen)
//#define MAXTEMP 28
#define MAXTEMP 34
//the colors we will be using
const uint16_t camColors[] = {0x480F,
0x400F,0x400F,0x400F,0x4010,0x3810,0x3810,0x3810,0x3810,0x3010,0x3010,
0x3010,0x2810,0x2810,0x2810,0x2810,0x2010,0x2010,0x2010,0x1810,0x1810,
0x1811,0x1811,0x1011,0x1011,0x1011,0x0811,0x0811,0x0811,0x0011,0x0011,
0x0011,0x0011,0x0011,0x0031,0x0031,0x0051,0x0072,0x0072,0x0092,0x00B2,
0x00B2,0x00D2,0x00F2,0x00F2,0x0112,0x0132,0x0152,0x0152,0x0172,0x0192,
0x0192,0x01B2,0x01D2,0x01F3,0x01F3,0x0213,0x0233,0x0253,0x0253,0x0273,
0x0293,0x02B3,0x02D3,0x02D3,0x02F3,0x0313,0x0333,0x0333,0x0353,0x0373,
0x0394,0x03B4,0x03D4,0x03D4,0x03F4,0x0414,0x0434,0x0454,0x0474,0x0474,
0x0494,0x04B4,0x04D4,0x04F4,0x0514,0x0534,0x0534,0x0554,0x0554,0x0574,
0x0574,0x0573,0x0573,0x0573,0x0572,0x0572,0x0572,0x0571,0x0591,0x0591,
0x0590,0x0590,0x058F,0x058F,0x058F,0x058E,0x05AE,0x05AE,0x05AD,0x05AD,
0x05AD,0x05AC,0x05AC,0x05AB,0x05CB,0x05CB,0x05CA,0x05CA,0x05CA,0x05C9,
0x05C9,0x05C8,0x05E8,0x05E8,0x05E7,0x05E7,0x05E6,0x05E6,0x05E6,0x05E5,
0x05E5,0x0604,0x0604,0x0604,0x0603,0x0603,0x0602,0x0602,0x0601,0x0621,
0x0621,0x0620,0x0620,0x0620,0x0620,0x0E20,0x0E20,0x0E40,0x1640,0x1640,
0x1E40,0x1E40,0x2640,0x2640,0x2E40,0x2E60,0x3660,0x3660,0x3E60,0x3E60,
0x3E60,0x4660,0x4660,0x4E60,0x4E80,0x5680,0x5680,0x5E80,0x5E80,0x6680,
0x6680,0x6E80,0x6EA0,0x76A0,0x76A0,0x7EA0,0x7EA0,0x86A0,0x86A0,0x8EA0,
0x8EC0,0x96C0,0x96C0,0x9EC0,0x9EC0,0xA6C0,0xAEC0,0xAEC0,0xB6E0,0xB6E0,
0xBEE0,0xBEE0,0xC6E0,0xC6E0,0xCEE0,0xCEE0,0xD6E0,0xD700,0xDF00,0xDEE0,
0xDEC0,0xDEA0,0xDE80,0xDE80,0xE660,0xE640,0xE620,0xE600,0xE5E0,0xE5C0,
0xE5A0,0xE580,0xE560,0xE540,0xE520,0xE500,0xE4E0,0xE4C0,0xE4A0,0xE480,
0xE460,0xEC40,0xEC20,0xEC00,0xEBE0,0xEBC0,0xEBA0,0xEB80,0xEB60,0xEB40,
0xEB20,0xEB00,0xEAE0,0xEAC0,0xEAA0,0xEA80,0xEA60,0xEA40,0xF220,0xF200,
0xF1E0,0xF1C0,0xF1A0,0xF180,0xF160,0xF140,0xF100,0xF0E0,0xF0C0,0xF0A0,
0xF080,0xF060,0xF040,0xF020,0xF800,};
Adafruit_AMG88xx amg;
unsigned long delayTime;
float pixels[AMG88xx_PIXEL_ARRAY_SIZE];
uint16_t displayPixelWidth, displayPixelHeight;
//Serial.begin(115200);
Serial.println(F("AMG88xx thermal camera!"));
tft.InitLCD();
tft.fillScr(0,0,0);
displayPixelWidth = tft.getDisplayXSize() / 8;
displayPixelHeight = tft.getDisplayYSize() / 8; //Keep pixels square
bool status;
// default settings
status = amg.begin();
if (!status) {
Serial.println("Could not find a valid AMG88xx sensor, check wiring!");
while (1);
Serial.println("-- Thermal Camera Test --");
delay(100); // let sensor boot up
//read all the pixels
amg.readPixels(pixels);
for(int i=0; i<AMG88xx_PIXEL_ARRAY_SIZE; i++){
int colorTemp;
if(pixels[i] >= MAXTEMP) colorTemp = MAXTEMP;
else if(pixels[i] <= MINTEMP) colorTemp = MINTEMP;
else colorTemp = pixels[i];
uint8_t colorIndex = map(colorTemp, MINTEMP, MAXTEMP, 0, 255);
colorIndex = constrain(colorIndex, 0, 255);
//draw the pixels!
tft.setColor(camColors[colorIndex]);
tft.fillRect(displayPixelHeight * floor(i / 8), 40 + displayPixelWidth * ((AMG88xx_PIXEL_ARRAY_SIZE - i - 1) % 8),
displayPixelHeight, displayPixelWidth);
#ifdef SHOW_TEMP_TEXT
tft.setColor(255,255,255); tft.setFont(SmallFont);
tft.printNumF(pixels[i], 1, 280, 80);
#endif
