AMG8833 with Nodemcu not reading temperature
#include <Wire.h>
  Wire.begin(D4, D3);
  while (!Serial); // Wait for Serial to initialize
  Serial.println("\nI2C Scanner");
  Wire.setClock(400000); // Set I2C frequency to 400kHz
  byte error, address;
  int nDevices;
  Serial.println("Scanning...");
  nDevices = 0;
  for (address = 1; address < 127; address++) {
    Wire.beginTransmission(address);
    error = Wire.endTransmission();
    if (error == 0) {
      Serial.print("I2C device found at address 0x");
      if (address < 16)
        Serial.print("0");
      Serial.print(address, HEX);
      Serial.println("  !");
      nDevices++;
    } else if (error == 4) {
      Serial.print("Unknown error at address 0x");
      if (address < 16)
        Serial.print("0");
      Serial.println(address, HEX);
  if (nDevices == 0)
    Serial.println("No I2C devices found\n");
    Serial.println("done\n");
  delay(5000); // Wait 5 seconds before next scan
The Above Code works properly and output I2C device found at address 0x69
But the example 'amg88xx_test' does not works and output shown is
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 3424, room 16
tail 0
chksum 0x2e
load 0x3fff20b8, len 40, room 8
tail 0
chksum 0x2b
csum 0x2b
v00042e10
~ld
⸮⸮⸮⸮o⸮{⸮⸮n|⸮ d⸮$`c⸮ ⸮|;⸮l⸮n⸮⸮n⸮
AMG88xx test
Could not find a valid AMG88xx sensor, check wiring!
Could I get help to solve this issue?
It would be a good idea to post that code also, and tell the forum where/how you installed the library.
Thank you for your quick response.
here is the code:
#include <Wire.h>
#include <Adafruit_AMG88xx.h>
Adafruit_AMG88xx amg;
    Wire.begin(D4,D3);
    Serial.println(F("AMG88xx test"));
    bool status;
    // default settings
    status = amg.begin();
    if (!status) {
        Serial.println("Could not find a valid AMG88xx sensor, check wiring!");
        while (1);
    Serial.println("-- Thermistor Test --");
    delay(100); // let sensor boot up
    Serial.print("Thermistor Temperature = ");
    Serial.print(amg.readThermistor());
    Serial.println(" *C");
    //delay a second
I installed the libarary through ardiuno ide>Tools> Manage Libraries> Searched for 'Adafruit_AMG88xx'> Downloaded version 1.3.2
If you change this to
  while (1) yield();
It should remove the watchdog errors you are getting. But it won't fix the problem that the amg.begin() call is failing. I don't know what is causing that. We know from i2c scanner that the device is visible on the bus.
I would do what the code suggest. Control that your wiring is short and solid.
I think if there was a problem with the wiring, the i2c scanner would not successfully detect the sensor.
Yep, except if wiring is flimsy.
Try adding this line at the top of your code
#define DEBUG_SERIAL Serial
to see what appears in serial monitor.
Thank you for your replies. I got my problem fixed by changing library from adafruit to sparkfun.
