AMG88xx Camera Display
Please correct this code
I am using 3.5'' UNO display driver ili9486 Dots:320x480 Touch:No
Original code file compatible with adafruit 1.44" display is attached. I tried to modify it but it didn't work ... can somebody help me where I am wrong?
This the code I modified for 3.5''. There is an attachment in which original code is attached (adafruit).
This is a library for the AMG88xx GridEYE 8x8 IR camera
This sketch makes a 64 pixel thermal camera with the GridEYE sensor
and a 128x128 tft screen Adafruit 1.44 Color TFT LCD Display with MicroSD Card breakout [ST7735R] : ID 2088 : $14.95 : Adafruit Industries, Unique & fun DIY electronics and kits
Designed specifically to work with the Adafruit AMG88 breakout
----> Adafruit AMG8833 IR Thermal Camera Breakout [STEMMA QT] : ID 3538 : $44.95 : Adafruit Industries, Unique & fun DIY electronics and kits
These sensors use I2C to communicate. The device's I2C address is 0x69
Adafruit invests time and resources providing this open source code,
please support Adafruit andopen-source hardware by purchasing products
from Adafruit!
Written by Dean Miller for Adafruit Industries.
BSD license, all text above must be included in any redistribution
#include <Adafruit_GFX.h>    // Core graphics library
//#include <Adafruit_ST7735.h> // Hardware-specific library
#include <Adafruit_TFTLCD.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_AMG88xx.h>
#define TFT_CS     10 //chip select pin for the TFT screen
#define TFT_RST    9  // you can also connect this to the Arduino reset
                     // in which case, set this #define pin to 0!
#define TFT_DC     8
#define LCD_WR A1
#define LCD_RD A0
#define BLACK   0x0000
//low range of the sensor (this will be blue on the screen)
#define MINTEMP 22
//high range of the sensor (this will be red on the screen)
#define MAXTEMP 34
//the colors we will be using
const uint16_t camColors[] = {0x480F,
0x400F,0x400F,0x400F,0x4010,0x3810,0x3810,0x3810,0x3810,0x3010,0x3010,
0x3010,0x2810,0x2810,0x2810,0x2810,0x2010,0x2010,0x2010,0x1810,0x1810,
0x1811,0x1811,0x1011,0x1011,0x1011,0x0811,0x0811,0x0811,0x0011,0x0011,
0x0011,0x0011,0x0011,0x0031,0x0031,0x0051,0x0072,0x0072,0x0092,0x00B2,
0x00B2,0x00D2,0x00F2,0x00F2,0x0112,0x0132,0x0152,0x0152,0x0172,0x0192,
0x0192,0x01B2,0x01D2,0x01F3,0x01F3,0x0213,0x0233,0x0253,0x0253,0x0273,
0x0293,0x02B3,0x02D3,0x02D3,0x02F3,0x0313,0x0333,0x0333,0x0353,0x0373,
0x0394,0x03B4,0x03D4,0x03D4,0x03F4,0x0414,0x0434,0x0454,0x0474,0x0474,
0x0494,0x04B4,0x04D4,0x04F4,0x0514,0x0534,0x0534,0x0554,0x0554,0x0574,
0x0574,0x0573,0x0573,0x0573,0x0572,0x0572,0x0572,0x0571,0x0591,0x0591,
0x0590,0x0590,0x058F,0x058F,0x058F,0x058E,0x05AE,0x05AE,0x05AD,0x05AD,
0x05AD,0x05AC,0x05AC,0x05AB,0x05CB,0x05CB,0x05CA,0x05CA,0x05CA,0x05C9,
0x05C9,0x05C8,0x05E8,0x05E8,0x05E7,0x05E7,0x05E6,0x05E6,0x05E6,0x05E5,
0x05E5,0x0604,0x0604,0x0604,0x0603,0x0603,0x0602,0x0602,0x0601,0x0621,
0x0621,0x0620,0x0620,0x0620,0x0620,0x0E20,0x0E20,0x0E40,0x1640,0x1640,
0x1E40,0x1E40,0x2640,0x2640,0x2E40,0x2E60,0x3660,0x3660,0x3E60,0x3E60,
0x3E60,0x4660,0x4660,0x4E60,0x4E80,0x5680,0x5680,0x5E80,0x5E80,0x6680,
0x6680,0x6E80,0x6EA0,0x76A0,0x76A0,0x7EA0,0x7EA0,0x86A0,0x86A0,0x8EA0,
0x8EC0,0x96C0,0x96C0,0x9EC0,0x9EC0,0xA6C0,0xAEC0,0xAEC0,0xB6E0,0xB6E0,
0xBEE0,0xBEE0,0xC6E0,0xC6E0,0xCEE0,0xCEE0,0xD6E0,0xD700,0xDF00,0xDEE0,
0xDEC0,0xDEA0,0xDE80,0xDE80,0xE660,0xE640,0xE620,0xE600,0xE5E0,0xE5C0,
0xE5A0,0xE580,0xE560,0xE540,0xE520,0xE500,0xE4E0,0xE4C0,0xE4A0,0xE480,
0xE460,0xEC40,0xEC20,0xEC00,0xEBE0,0xEBC0,0xEBA0,0xEB80,0xEB60,0xEB40,
0xEB20,0xEB00,0xEAE0,0xEAC0,0xEAA0,0xEA80,0xEA60,0xEA40,0xF220,0xF200,
0xF1E0,0xF1C0,0xF1A0,0xF180,0xF160,0xF140,0xF100,0xF0E0,0xF0C0,0xF0A0,
0xF080,0xF060,0xF040,0xF020,0xF800,};
Adafruit_TFTLCD tft(TFT_CS,  TFT_DC, LCD_WR,LCD_RD, TFT_RST);
Adafruit_AMG88xx amg;
unsigned long delayTime;
float pixels[AMG88xx_PIXEL_ARRAY_SIZE];
uint16_t displayPixelWidth, displayPixelHeight;
   Serial.println(F("AMG88xx thermal camera!"));
   //tft.initR(INITR_144GREENTAB);   // initialize a ST7735S chip, black tab
  // tft.fillScreen(ST7735_BLACK);
tft.fillScreen(BLACK);
   displayPixelWidth = tft.width() / 8;
   displayPixelHeight = tft.height() / 8;
   //tft.setRotation(3);
   bool status;
   // default settings
   status = amg.begin();
   if (!status) {
       Serial.println("Could not find a valid AMG88xx sensor, check wiring!");
       while (1);
   Serial.println("-- Thermal Camera Test --");
   delay(100); // let sensor boot up
 //read all the pixels
 amg.readPixels(pixels);
 for(int i=0; i<AMG88xx_PIXEL_ARRAY_SIZE; i++){
   uint8_t colorIndex = map(pixels[i], MINTEMP, MAXTEMP, 0, 255);
   colorIndex = constrain(colorIndex, 0, 255);
   //draw the pixels!
   tft.fillRect(displayPixelHeight * floor(i / 8), displayPixelWidth * (i % 8),
       displayPixelHeight, displayPixelWidth, camColors[colorIndex]);
original.txt (4.4 KB)
Please follow the "how to use this forum" guidelines.
I bet that the original code did not have italics and did not have emoji. Therules are there for a reason.
OK, but "didn't work" isn't very helpful. The code does something. If this something is not the something you were expecting, tell us what you expected and what it actually did.
Can you get the simpler examples to work? Can you print "hello" or anything onto the screen? Can you get any values from the sensor?
Actually I want real time display of thermal image camera AMG88xx on my screen. Adafruit has given us code which is attached (original post). They made for 1.4" display (driver : ST7735) however I am using 3.5" display( driver : ili9486).
Yes by using this code I can print different things.
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_RESET A4
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
  tft.reset();
  tft.begin(0x9481);
  tft.setRotation(1);
  tft.fillScreen(RED);
  tft.fillScreen(GREEN);
  tft.fillScreen(BLUE);
  tft.setCursor(80,100);
  tft.setTextColor(WHITE);
  tft.setTextSize(4);
  tft.print("Hello");
  tft.setCursor(220,100);
  tft.setTextColor(RED);
  tft.setTextSize(4);
  tft.print("YouTUBE!");
  tft.fillRect(80,200, 321, 60, RED);
  tft.setCursor(135,215);
  tft.setTextSize(4);
  tft.print("Subscribe");
  tft.drawRect(0,0,480,320,WHITE);
  tft.fillRect(80,200,321,60,BLACK);
  tft.fillRect(80,200,321,60,RED);
  tft.setTextSize(4);
Thanks
Ok. Step2: are you getting any values from the sensor?
Step3: can you print just one value to the screen as a number?
I suspect the problem is the color array. The two displays likely have a different representation of colors. Try to make it work with brightness levels of a single color.
