Hi to all.
i have build a small weather station that i transmit some data i have collected with my arduino to a server.
i am using sim800l module to send the data through gprs
Everything working fine but would like to know if there is any method or command to read how many bytes of data i am sending in order to calculate my sim card plan from my mobile provider (how many Mb will have every month )
i dont know if that helps but when i send the command "AT+HTTPACTION=0" i am getting as response "+HTTPACTION: 0,200,2"
here is what i am sending :
/// type of variables of my sensors ////
int Sensor01Data;
int Sensor02Data;
int Sensor03Data;
int Sensor04Data;
int Sensor05Data;
int Sensor06Data;
float Sensor07Data;
int Sensor08Data;
float Sensor09Data;
float Sensor10Data;
float Sensor11Data ;
/////////////////// code that i am sending with At command ////////////////
mySerial.print("AT+HTTPPARA=\"URL\",\"http://www.mywebsite.com:7080/incomingdata_test.php?sensor01=");
mySerial.print(Sensor01Data); // variable of
mySerial.print("&sensor02=");
mySerial.print(Sensor02Data); // variable of
mySerial.print("&sensor03=");
mySerial.print(Sensor03Data); // variable of
mySerial.print("&sensor04=");
mySerial.print(Sensor04Data); // variable of
mySerial.print("&sensor05=");
mySerial.print(Sensor05Data); // variable of
mySerial.print("&sensor06=");
mySerial.print(Sensor06Data); // variable of
mySerial.print("&sensor07=");
mySerial.print(Sensor07Data); // variable of
mySerial.print("&sensor08=");
mySerial.print(Sensor08Data); // variable of
mySerial.print("&sensor09=");
mySerial.print(Sensor09Data); // variable of
mySerial.print("&sensor10=");
mySerial.print(Sensor10Data); // variable of
mySerial.print("&sensor11=");
mySerial.print(Sensor11Data); // variable of
mySerial.println("\""); // THIS IS WHERE THE 'ln' comes in
thanks in advance
