Amplifier Causing Whiny Sound
So I have a setup where I have the arduino making a tone, that then goes to an amplifier circuit from my Snap Circuits set, and it works fine. The problem is that when no tone is being sent to the input, I get a hissy, whiny sound when the input is connected.
So whenever I have a tone signal, it works fine, but when no signal is sent, I get a really annoying sound.
Any help or note of what's happening?
Chrome7fan:
So ...... if you deliberately ground the input ...... so that the input is basically 0V AC, then you get some undesired hissy/whining noise?
Does this also mean that ...... when your arduino is generating a relatively high level tone, then no whining noise. But.... if you then purposely set the arduino to generate a relatively low level (relatively low AC voltage tone ....via some kind of D/A module), then you can hear significantly whining noise?
Southpark:
No, I don't have a DC input. I'm using a PWM digital output from the arduino, sending it through a different branded amplifier, and outputting it to a speaker.
The problem occurs when there is no voltage going into the AMPS input. As I hear a sound still coming through, but it's not a tone.
I see .... if this particular amplifier is making unusual unexpected noise when nothing is connected to this amps input, then it's possible that it has a circuit problem (component gone out of specs maybe). Has this always occurred? Or it's a new amp? If it is making whining noises, then that could be system instability ...... self-oscillations, which is not what an amp designer wants.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.. :slight_smile:
