Hi, i'd like to know if a can amplify the voltage range of the arduino from 0-5V to 0-10V with a boost converter?
Tks..
Tks..
Do you have a 10V supply available? If so, can just have the arduino output control a transistor whose output then switches at 0-10V level.
Otherwise, you need charge-pump kind of circuit such as is found in MAX232 where caps are used with switching circuitry to get +/-10V levels out.
tks.. I don't have the supply of 10v, i have to use the voltage of the arduino
How much current? uA? mA? A?
