Hi, I'm trying to deal with conditioning the signal of a Honeywell Durafet III pH sensor for use with an arduino. By using the Durafet (7777DVP) together with its cap adapter (P/N: 51453388-002), I get a pH signal whose output is a range from -300mV to 300mV.
To make things more complicated, I need to trim the range because the arduino A/D converter is 8 bits only, so I would like to take only a short fraction of the full output range, for example, the -10mV to 100mV (but this has to be variable) and amplify to a standard 0-5V to be able of using the arduino.
Could somebody give me some help?
Thanks in advance
A simple way to do this is enclosed.
Set the analog reference to 1.1v, and you'll get nearly 9 bits resolution from the arduino's 10-bit a/d
regards
Allan
pHif.pdf (16.9 KB)
No it is not. As Allan says it is 10 bits.
allanhurst:
A simple way to do this is enclosed.Set the analog reference to 1.1v, and you'll get nearly 9 bits resolution from the arduino's 10-bit a/d
regards
Allan
Many thanks for your help and your time to do the circuit.
I'm very newbie in general electronics knowledge, so all this help from both is very appreciated.
I delayed this post because I was trying to fully understand your response.
As I wasn't able to calculate by hand the output voltages in your circuit (my fault), I tried to simulate it by using some apps I tried. Luckily, I was able to get your output V values with circuitlab and a TL431 model , so this can help me a lot to deal with the sensor.
Again, thanks for this, as your circuit avoids negative voltage values in sensor output (and I didn't know how to deal with them). I'll put some effort in trying to understand your advice of putting analog reference to 1.1V.
I thought that A/D converter was 8 bits because i read somewhere that output was a uint8. Having 9 or 10 bits would be nice (16 or even 24 would be perfect), as the durafet sensor is very precise, so this impacts directly in the precision I could get in the end. Still, I would need to get some kind of amplification to deprecate extreme values and being able to use full arduino A/D scale for a narrow range from sensor.
I'll try to advance on this in parallel with some other open fronts, as I've to be able to (first) power the sensor (-3V,GND,+3V) and also to read the temperature sensor...
Thanks,
Anton
Output is not input - yes, the analogWrite output values are 8 bit, but that unrelated.
If 10 is nice but 24 is perfect, its hard to know what your requirement actually is! Presumably
you want a certain precision in terms of pH units...
MarkT:
Output is not input - yes, the analogWrite output values are 8 bit, but that unrelated.If 10 is nice but 24 is perfect, its hard to know what your requirement actually is! Presumably
Exactly, I would like 0.001 precision in pH units. As the -300mV to 300mV from the sensor accounts for the full range from 0 to 14, I would need 14 bits for this (14/2^14=0.0008) if I'm able to translate the range to the full A/D range. Allan circuit gives me 0.01 to 0.44V (and solves negative voltage problems), so I will lose a lot of range if use it in a 0-5V input directly, so I think I should apply some gain (without adding noise). However, I think I've some kind of alternatives:
1.- If I could use a 24bit A/D converter, that 0.01..0.44V range in volts would not be a problem (AFAIK), as even when used in a 0..5V input that 0.43V range would mean a precision of about 1E-5 in pH units, meeting and even exceeding my requirements (If this way doesn't have any other implications in precision).
2.- The other approach could be to narrow the range and applying some gain. I think I could discard out of range values for my application, focusing, for example in the range 6.9..8 pH units. That would mean that I could use a 10bits A/D (1.1/2^10=0.001) for meeting the required precision. If I could amplify that 6.9..8 (it means -0.04..0.43V from sensor) to 0..5V, that would also be another option.
Thanks for your interest and time.
0.001 pH? Wow.
So you definitely need a 14 or 16 bit ADC with a reference input, a precision voltage reference, and
an opamp circuit to boost the incoming signal.
Or a chip with all of that built in like the MCP3426 http://ww1.microchip.com/downloads/en/DeviceDoc/22226a.pdf
(Well you still need to shift the voltage... perhaps the differential inputs will finesse that issue)
MarkT:
0.001 pH? Wow.So you definitely need a 14 or 16 bit ADC with a reference input, a precision voltage reference, and
an opamp circuit to boost the incoming signal.Or a chip with all of that built in like the MCP3426 http://ww1.microchip.com/downloads/en/DeviceDoc/22226a.pdf
It's me who says wow!!
Your advice about MCP3426 is impressive and sounds great!
As I've read in specs, the gain amplifier is programable by I2C, and that solves a BIG problem for me as avoids the need to build this. Having the differential outputs looks also very promising to deal with -0.3..0.3V. Finally, having two channels is also a good improvements as the second one could probably deal with the temperature measurement.
And as an very appreciated extra value, I've found the MCP3426 as arduino module here: https://www.controleverything.com/content/Analog-Digital-Converters?sku=MCP3426_I2CADC
This simplifies things a lot for me.
Many thanks for your advice.
PD: About the 0.001 requirement in precision, that it's probably around the limit of the sensing capabilities of the durafet piece (it's an Ion-Sensitive FET), but some authors report that it's easily achievable.
Differential inputs. And no you cannot apply a negative voltage to any pin, they must stay between GND
and Vcc, BUT if you have your pH meter at a floating potential w.r.t. the ADC/Arduino, you can feed the
two wires to differential input pins, and adding a potential divider (2 10k resistors the GND and Vcc)
to keep one of the wires at mid-range of the ADC.
If you cannot isolate the systems, you'll need a stage of differential amplification with an op-amp, probably
just a unity-gain differential amplifier configuration using a quality opamp (low offset voltage).
Just breathing CO2 at a solution might swing the pH that amount I'd have thought!
MarkT:
Yes. In fact, that is, in a manner, one of the deployment scenarios. A big tank of seawater bubbled with air with a known concentration of CO2. Last time we derived the pH from the CO2, but this time we want to measure that pH continuously.
If you need 16-bit resolution my original suggestion is inadequate.
You presumably need a +/- supply to drive your sensor - you mentioned +/- 3v
Run the a/d from that , and use level translators to get the I2C to the arduino 0... +5 levels.
regards
Allan.
