Amplifying small DC signal
Hello guys,
I want to amplify the small DC signal that produced by O2 sensor. So, it can be read by Arduino. I change AD8572 to OP07CP Op Amp because AD8572 is a SMD type component. But the problem is, I unable to amplify the signal that received from O2 sensor. There is any idea how to amplify the signal?
  • The output voltage at SIG OUT is around 0.5V.
  • After I connect -5VDC to the amplifier circuit, the voltage drop to -2.8VDC.
  • All +5VDC are using Arduino Mega +5VDC supply.
Attached is the OP07CP, AD8572 datasheet and circuit.
http://www.ti.com/lit/ds/symlink/op07c.pdf [OP07CP]
http://www.analog.com/media/en/technical-documentation/data-sheets/AD8571_8572_8574.pdf [AD8572]
-5VDC Supply
Amplifier Circuit
The -5V circuit is limited in how much current it can supply.
With such a small load, it is odd that the -5V supply isn't working.
Is your amplifier the only thing that is connect to -5V ?
Yes. Only amplifier circuit. There is any possibilities of short circuit?
Will you show us an image of your wiring?
Do you have a decoupling capacitor on pin VCC?
Edit:
I would put them on pin 1 and 8 also.
Dear Larry,
This is the picture of my circuit.
"I would put them on pin 1 and 8 also."
What did you mean?
Edit:
The picture of the circuit.
What did you mean?
On your amplifier, put .1uF capacitor on each pin to ground.
I cannot confirm the colors on your actual resistors in the photo.
What are the colors?
Test:
To check the -5V drive capability, disconnect the Amp from the -5V supply.
Try different resistor (10K, 4.7K, 2.2K, 1K, 560R) values on the -5 output to ground (0V).
At what value does the -5V level start to drop below -4.5V.
nazreen:
Seems normal for the NE555. Look at the datasheet.
"Low" volt drop is ~0.2v@10mA, but "high" volt drop is ~1.5volt@10mA.
That gives a square wave of 3.3volt t/t@10mA.
Plus the rectifier diode drop.... (schottky diodes are better here).
You could use a PWM Mega pin (or two pins in push-pull) to generate -5volt.
Leo..
The OP07CP is not rail to rail type, the output can only get to within a few volts of the supply rail at best.
Furthermore, I think your oxygen sensor (type?) would have a unipolar output but your amplifier circuit is bipolar type.
There are a few through hole op amps available that have comparable features to the AD8572 (single supply, rail-rail, low drift, etc). Perhaps this one is close enough: ALD1702
The OP07C needs at least 3V clear of each rail, get a low voltage R2R opamp and forget
about using 1980's opamp chips! They are usually intended for +/-15V.
What is the part number/ type of your O2 sensor?
Do they advise on amplifiers and how to connect to arduino?
Thanks Tom........ :slight_smile:
Hello guys, sorry for the late reply,
TomGeorge:
This is the sensor datasheet.
English
Chinese (with circuit diagram)
MarkT:
dlloyd:
Well, you have the point. But, it's hard for me to find that type of IC in my place.
Correct me if wrong but well as I remember non inverting amp gain factor is (feedback R / input R), less than 1 in this case?
This circuit has gain of 83, probably the best you can do without being limited by the upper rail. Reading Arduino's analog input should give range of 0-374. Could add a series resistor of around 4.7K to protect Arduino's input in case the signal ever goes negative (i.e. powerup).
dlloyd:
Yes, I got the idea. I try to reassemble the circuit and the result is positive I think. There is some changes in value but it's small. BTW, the output voltage is 0.84V. I dont't know either it caused by normal oxygen level or there is something wrong with my circuit. Need to test it in vacuum chamber.
*P/S: For feedback resistor I change it to 20k because I don't have 82k resistor right now and for negative voltage, I just connect it to GND.
nazreen:
......and for negative voltage, I just connect it to GND.
Can't do that.
For the output to go to zero volt, the negative supply has to be at least -2volt.
A supply of +5volt and -2.8volt is fine.
The output can then swing between -0.8volt and +3volt. Maybe a bit more.
You have to read that with a lower Vref enabled if you want the full range of the 10-bit A/D.
As said, use a resistor between opamp and Arduino pin (4k7-10k), to protect the Arduino input.
Leo..
Have you got pin2 connected to pin6 on the LM555, it is hard to see.
Tom..... :slight_smile:
Wawa:
Can't do that.
Leo..
After I change it, the output voltage increase to 3.94V and sensor become less responsive.
TomGeorge:
Yes.
nazreen:
Maybe the opamp just started to work.
Did you "load" the sensor with a 100ohm resistor, as on the datasheet.
Without load resistor, the sensor might produce a higher output voltage.
That could explain the maximum output voltage (clipping) of the opamp.
Leo..
For future single supply projects:
