Amulet Smart Display
I just picked up an Amulet Smart Display from here: http://www.vetco.net/catalog/product_info.php?products_id=14116
Datasheet: http://vetco.net/datasheets/VUPN6872/MK-AOB3202405B,N,T.pdf
HTML Help: HTMLCompiler Help
The Amulet Smart Display will compile HTML documents to the microcontroller on board and process Java, HTML, and images. This is quite easy to program, and I've worked with 16x2, 20x4 LCDs in the past, but never anything like this before.
I'm not sure how to use my Arduino with the Amulet Smart Display. I would like to be able to update the LCD or pull dynamic data from the Arduino, but I haven't see any examples for this. For example, use the Arduino to connect to the Internet to pull some data, if the data is true then display x, if not display y. I have done this with a simple LCD, but I'm unsure on how to do it with this.
Looking at the data sheet, there are TXD and RXD pins, which the Arduino supports, but I've never worked with them to display data in this manner.
Thanks,
NullPtr
So, I have a little bit of information, but I'm not sure how to implement it. The LCD uses UART through the TX and RX pins on the Arduino on the board and on the LCD.
You use this code on the Arduino or any other C/Asembly/BASIC enabled controller and call it with these functions.
But, I'm not exactly sure which functions to use to send and receive data, and how to update the text on the LCD.
Bump.
