An algorithm for reading songs according to mood from any SD/micro-SD card or SP
Hello friends, my question is that-HOW!!!! to make an algorithm for selecting music according to mood from any SD/micro-SD CARD or if possible from the whole memory of the smartphone. If anybody has time please mention the whole code. PPPPPPPPPPPPPPPPLLLLLLLLLLLLLLEEEEEEEEEEEEEEEEEEAAAAAAAAAAAAAAAAASSSSSSSSSSSSSSSSSSEEEEEEEEEEEEEEEEEEEEEEE. I know you can do it.
THANKS. :) :) :)
I found a solution on the web at http://127.0.0.1
Does not always respond, just keep trying.
according to mood
How are you determining the Arduino's mood?
It is NOT possible to extract music files from the phone without it's cooperation.
How is the Arduino going to play the music, anyway?
PaulS: How are you determining the Arduino's mood?
The Arduino's mood is of course stored in a variable. Duh! Except if it has blown its fuses.
I am doing this by sensing body's heat. Different body heat in different body parts indicates different mood. By using a thermistor or TMP35. I have did a research on it.
chemayush: PPPPPPPPPPPPPPPPLLLLLLLLLLLLLLEEEEEEEEEEEEEEEEEEAAAAAAAAAAAAAAAAASSSSSSSSSSSSSSSSSSEEEEEEEEEEEEEEEEEEEEEEE.
I don't understand that.
You want us to write code for you?
Rupert909: I found a solution on the web at http://127.0.0.1
Cute. :D
Why is this in "Robotics"?
AWOL: Cute. :D
Perhaps he's trying to create a moody robot? In other words, Marvin! :-D
