An analog keypad. Will it work?
Someone was asking for a solution to sensing 48 buttons. I thought since I might need a solution to a similar problem, I mocked up a diagram that uses 1 analog pin, 8 digital pins, and 7 resistors. Will it work?
The digital pins will be pulled to GND for the active column and left in tri-state for non-active columns.
Thanks.
Yes, you must scan allong the pins to see which row has a pressed button.
something like this (not tested)
int keypress()
int x;
int row = -1;
int key;
for (int i=0; i< 8; i++)
  digitalWrite(pin[i], HIGH);
  x= analogRead(A0);
  digitalWrite(pin[i], LOW);
  if (x  < THRESHOLD)
     row = i;
if (row > -1)
  return 8*row + lookup(x);  // to do ;)
return -1;
you could also use a shift register serial in parallel out (needs 3 lines IIRC) - http://arduino.cc/en/Tutorial/ShiftOut -
shift in 1 bit high and then clock it from bit 0 to 7 -
don't use shiftOut() but do the clocking in your own pace!
how about this project 64 using a MCP23S17 - Project64 -
there are some nice videos too :wink:
In theory you could get away with no more than two analog pins, I believe...
in theory with one analog pin and 48 very precize resistors, say 100 ohm + 5240 ohm
would give 48 steps from 0 to 500 in analogRead => so diff between 2 values is about 10 - just larger than noise (~2 bits)
advantage is that the SW would become very simple: button = analogRead(A0) / 10;
However in practice ....
I had not even considered that. I like that approach.... :slight_smile:
Rob,
Thanks for the link. There's no code on the site though. I was a bit concerned when driving with a port extender but since this extender has an open-drain mode, there won't be problems. Still one needs to use it so inactive columns are not driven to opposite polarity. It would short if you drive column 0 to high and 1 to low and hold two buttons one from column 0 and one from 1. If I use arduino pins under tri-state mode, the problem is solved.
I think I will give my own schematic a try with a membrane matrix keypad. I have a bunch at home. Next time I order from digikey, I'll grab a few of those port extenders. :slight_smile:
it is not visible as a hyperlink, just click on the filename and you fly to - 404 -
Thanks Rob!
