An Arduino to control multiple wall plugs
Hi!
I recently developed an electronic project to control power outlets with my smartphone, from anywhere in the world. It was a great challenge for me, as this is my largest project with an Arduino so far.
Basically I used a cheap 3-pack remote controlled power outlets (around $12), then I connected the remote to my Arduino and with an Ethernet module I connected all that to the Internet.
The final goal was to control my Christmas tree lights with all kind of unusual ways Fun ways to light up the Christmas tree
I also documented the project in a video DIY Internet controlled power outlets with an Arduino
Schematics:
Code in the Arduino: GitHub - FriesFlorian/treeawesome: Arduino code to control stuff with a built-in webserver
And more informations on this blog post: A connected Christmas
Tell me what you think about all this :slight_smile:
Thanks, and also Happy new Year!
Florian Fries
Not sure why you used the relay module to interface with the remote control?
PasiO:
He is basically replacing the buttons on the remote. I guess that's one way to do it, as if he wanted to connect directly using the pins on his board he would need to have the same voltage as the remote uses.
It's a cool solution, even though you've made a remote for a remote :stuck_out_tongue: If I were you I'd remove the enclosure for the remote and mount the boards somehow, but it works well as it is.
OscarLimaEcho:
Ah, I overlooked the chance of having different voltages, I was lucky enough to have 5V on the remote I hacked into. Though if the remote was working with logic below 5V (which would be likely?), you could still possibly work without extra components (if the pin on the remote was to be driven low) or with a resistor divider (if pin to be driven high).
Anyway, glad he did it that way... gave me an idea for a future project:)
