An audio message storing system. is it possible?
Hi… I need a little help. I am trying to convert real time audio into .wav because arduino required .wav. is it possible? What I am basically trying is to covert audio signal into digital data with ADC and then I weant to store it on an SD card! then feed this data to a DAC and get back the audio signal…
But is it possible to store and read data from file and feed it to DAC?
If not is there a way to use this data n generate a .wav file?
I have an Arduino Uno board!
Here I am posting overview of my idea… Please check it…
https://drive.google.com/folderview?id=0B7bjTcwv4NimekR4ZUlqVzg0VmM&usp=sharing
Hope someone can help… And suggestions are also welcome!
Thank you!
Sure is. All you need is a PC and a sound card and a microphone.
What I am basically trying is to covert audio signal into digital data with ADC and then I weant to store it on an SD card! then feed this data to a DAC and get back the audio signal...
Not on an Arduino. Except maybe the DUE.
Yes.
and feed it to DAC?
What DAC? Most Arduinos don't have a DAC.
We can interface one with I2C, right?
You can. Then, you'll have a really slow ADC connected via a slow bus to a DAC. Doesn't sound like the recipe for good DSP to me. The Arduino is not a DSP.
