I am currently defining what code has to get executed under which conditions, here which switches are set. Is there a more elegant way to organize this code?
//read the Poti Pin value and constrain it between 14 - 1005 instead 0 - 1023
constrainedPoti = POTI_READ_AND_LIMIT(analogRead(Poti_Pin), 14, 1005);
//playerSoftware0.setVolume(Pot_percentage_val); -> IMPLENET SOMEWHERE LATER
//PROGRAM_POTI_VENT_BRIGHNTNESS(constrainedPoti); -> IMPLEMENT LATER
// Serial.print(static_cast<int>(WandStartSequence));
//Serial.print(" ");
//Serial.println(hasBooted);
if (!SW_Vent.read()) {
COMPLETE_RESET();
POROGRAM_CYCLOTRON_OFF();
if (SW_Vent.read() && !hasBooted) {
hasBooted = PROGRAM_BOOTING();
if (SW_Vent.read() && hasBooted && !SW_BarGraph.read()) {
BLINK_FUNCTION_LED_OF_SEGMENT(BarGraph_Segment, 0);
PROGRAM_LED_IDEL_PUMP_UP(Power_Cell_Segment, PowerCellIdle, PowerCellIdleTimer);
if (SW_Vent.read() && hasBooted && SW_BarGraph.read() && !SW_StartUp1.read() && !SW_Intensify.read()) { // add Ventlight <= max specified in bootup
PROGRAM_LED_IDEL_PUMP_UP(BarGraph_Segment, barGraphIdel, BarGraphIdleTimer); //put powercell idle timer in a new class
if (SW_Vent.read() && hasBooted && SW_BarGraph.read() && SW_StartUp1.read() && !SW_Intensify.read()) {
PROGRAM_LED_IDEL_PUMP_UP(BarGraph_Segment, barGraphIdel, BarGraphIdleTimer); // implement reset
PROGRAM_CYCLOTRON_IDLE();
if (SW_Vent.read() && hasBooted && SW_BarGraph.read() && SW_StartUp1.read() && SW_Intensify.read()) {
PROGRAM_LED_IDEL_FIRING(BarGraph_Segment, barGraphFire);
if (SW_Vent.read() && hasBooted && SW_BarGraph.read() && SW_StartUp1.read() && !SW_Intensify.read() && SW_Intensify.toggled()) {
//PROGRAM_LED_IDEL_PUMP_UP(BarGraph_Segment, barGraphIdel, BarGraphIdleTimer); // implement reset
BarGraphIdleTimer = 0; // resets the bargrapg to zero and starts again from the bottom
PROGRAM_LED_OFF(BarGraph_Segment);
// just for checking
if (SW_WandTip.read()) {
Serial.println("Wand-Mode");
Two seem to have duplicate actions (slightly reformatted for clarity)
If it's blah blah blah blah and !SW_Intensify.read(), then do this. But then if it's the same and also SW_Intensify.toggled(), do something similar a second time?
To avoid repeating each read and to ensure the actions are mutually exclusive, you might try
if (SW_Vent.read()) {
if (hasBooted) {
if (SW_BarGraph.read()) {
auto startup1 = SW_StartUp1.read();
auto intensify = SW_Intensify.read();
if (startup1 && intensify) {
} else if (startup1 && !intensify) {
if (SW_Intensify.toggled()) {
} else if (!startup1 && !intensify) {
} // unused: !startup1 && intensify
} else { // !SW_BarGraph.read()
} else { // !hasBooted
} else { // !SW_Vent.read()
Note this takes the nested
if not-condition
and avoids the not, turning the list "upside-down"; because each ! makes the conditions more complex to reason about, especially for someone not familiar with the system. If it really makes more sense to have the ! so that the options are "in order", you can keep it.
Toward the end, two of the conditions are stored in variables, and the tests are flattened slightly to avoid too much nesting. It also shows that instead of four combinations, only three are used. So maybe that part instead might be
if (SW_StartUp1.read()) {
if (SW_Intensify.read()) {
} else if (SW_Intensify.toggled()) {
} else { // !SW_StartUp1.read()
if that is actually how it is supposed to work (three different possibilities).
With nested if-blocks, the cold folding feature of the editor can be handy.
In Short I want to use different LED blinking stuff in dependencies of whether or not a button/ switch has been changed or not.
For example here until the first switch has been switched and the boot up sequence has not been fnished you are not allowed to use the functions of any other switch
the button on the left can only be pressed and the alternating yellow leds will flash, after all other switches have been switched on in the right order.
I also have to add more dependencies to the function.
That's why I am asking for a good way to write down all dependencies and after that program the right conditions of if a switch has been switched or not.
Maybe there a some techniques that are usually be used for this kind of stuff like writing down a table with all the states or else.
checks if the first switch the one in my video on the top is switched on.
after it has been switched on and the boot sequences has been finished the variable "hasBooted" gets true instead of false.
OK - some button library would return "pressed" only once when the button changes state. are you checking the state or the change of state with your read() function and are you 100% sure that read() I debounced? (which library do you use?)
thanks.
the code isn‘t complete yet. first i want to get all buttons and functions working as they should and then i‘ll clean up the mess with your suggestions.
can you provide me a link to the cold folding feature of the arduino ide? i couldn‘t find reliable stuff via a quick search.
My google autocorrected the error… so just in case
So how do you actually fold code well. It's pretty simple and an Arduino IDE 2 and Arduino ide1. You can simply go over to the margin of the code click that little arrow.
The cold folding in the wokwi simulator is not limited to { collapsing }, which is all the the IDE editor seems to offer unless I am missing something.
IDE 1.8.7, BTW, my forever portable IDE… and wouldn't you know, IDE 2.3.2 dropped support for the OS I am using.
Oh, wait. IDE 1.8.15 - maybe it is improved. Now I think I had trouble getting anything leter to run, oh well.
