an error occured while uploading the sketch
hi every one,
I am getting an error while uploading the sketch. please help me with this one. I am attaching my code file and error file too.
Sketch uses 3832 bytes (11%) of program storage space. Maximum is 32256 bytes.
Global variables use 89 bytes (4%) of dynamic memory, leaving 1959 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM1 -b115200 -D -Uflash:w:C:\Users\user\AppData\Local\Temp\arduino_build_332700/sketch_nov04a.ino.hex:i
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM1
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: ser_open(): can't open device "\\.\COM1": The system cannot find the file specified.
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
#include<LiquidCrystal.h>
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
const int analogInPin = 13;
const int SensorValueLow = 463;
const int SensorValueDiff = 36; // differance between high and low sensor value
const int TempValueDiff = 42; // differance between high and low Temp value
const int TempValueLow = 9;
int sensorValue = 0;
double Temp = 0;
byte degree[8] =
                0b00011,
                0b00011,
                0b00000,
                0b00000,
                0b00000,
                0b00000,
                0b00000,
                0b00000
 lcd.begin(16, 2);
 lcd.createChar(1, degree);
 lcd.clear();
int tempPin=13;
  sensorValue = analogRead(analogInPin);
  Temp = sensorValue-SensorValueLow;
  Temp = Temp/SensorValueDiff;
  Temp = Temp*TempValueDiff;
  Temp = Temp+TempValueLow;
  lcd.setCursor(0,0);
  lcd.print("Value = ");
  lcd.setCursor(7,0);
  lcd.print(sensorValue);
  lcd.setCursor(0,1);
  lcd.print("Temp = ");
  lcd.setCursor(7,1);
  lcd.print(Temp);
  delay(200);
error message.txt (1.07 KB)
temperature measurement.txt (1.09 KB)
Select the port of your Arduino from the Tools > Port menu. If that menu is grayed out or the port of your Arduino board is not shown then one of the following may be the cause:
  • You may need to install the driver for the USB-serial chip on your Arduino. Determine which chip is used on your Arduino and install the driver.
  • You may be using a charge-only or defective USB cable. Test your cable on another device to confirm that it works for data.
The problem has nothing to do with your code.
